IMSA Road America Aug 3rd
by teamzr1. 08/03/25 02:30 PM
by teamzr1. 08/02/25 07:36 PM
ZR1-X Verus Ford Mustang GTD War
by teamzr1. 08/01/25 04:33 PM
GT America @ VIR
by teamzr1. 07/20/25 08:33 AM
Another C8 Model Coming ?
by teamzr1. 07/15/25 02:05 PM
by teamzr1. 07/14/25 10:41 AM
by teamzr1. 07/14/25 05:52 AM
C8 Corvette Wins GT Asia Race
by teamzr1. 07/13/25 03:54 PM
C8 Cop Cruiser is the Winner
by teamzr1. 07/12/25 08:51 AM
by teamzr1. 07/10/25 02:52 PM
2026 Corvette ZR1X in Amplify Green Metallic
by teamzr1. 08/05/25 01:05 PM
Con Artists and C8 ZR1s
by teamzr1. 08/04/25 12:43 PM
RHD C8s to Sell in Singapore
by teamzr1. 08/01/25 05:17 PM
by teamzr1. 07/31/25 08:57 AM
EPA Power gets Reduced Again
by teamzr1. 07/30/25 09:55 AM
Topics3,633
Posts6,763
Page 2 of 3 1 2 3
#2835 - 10/14/08 01:35 PM Re: Injectors offset voltage times not created equal [Re: teamzr1]
tici
Here the results:
0% offset change (stock) => Fuel Trims = +1.73% (FTC 6-14) and +1.70% (FTC 1-19)
+10% offset change => Fuel Trims = +0.14% (FTC 6-14) and -0.91% (FTC 1-19)
-10% offset change => Fuel Trims = +3.12% (FTC 6-14) and 3.39% (FTC 1-19)
The fuel trims values are a sum of LTFT and STFT (this to give a more precide result).
I averaged the counts and not the cells, so those numbers are a weighted average and give the real pictuer of the thing.
With -10% offset something is strange... it's not too bad but it's like an old car with a compression problem. A little asleep sleep
#2836 - 10/14/08 04:46 PM Re: Injectors offset voltage times not created equal [Re: ]
In your case
#2837 - 10/15/08 01:00 AM Re: Injectors offset voltage times not created equal [Re: teamzr1]
tici
Here the results as a graph
#2839 - 10/15/08 09:05 AM Re: Injectors offset voltage times not created equal [Re: ]
I would do tuning tests with both -10 and +10 as to injector IFR table and see which one you like best.
#2840 - 10/15/08 11:09 AM Re: Injectors offset voltage times not created equal [Re: teamzr1]
tici
OK let me try.
would you try with even bigger changes? like +/- 20%?
Do you see a reason why increasing the delay time (= advancing the fuel injection) the engine reacts better?
I can't express it in numbers, but it's one of those improvements that put a smile on your face when you test drive the car.
Better fuel vaporisation?
#2846 - 10/16/08 08:20 PM Re: Injectors offset voltage times not created equal [Re: ]
#2847 - 10/17/08 02:36 AM Re: Injectors offset voltage times not created equal [Re: teamzr1]
tici
I see.
The voltage is between 13.5 and 14 depending in the electrical load (lights, defogger, fan...).
I'll probably tweak the region between 12.5 and 15 V
My version of LS1Edit can read only 97-98 programs.
Could you take a look at the differences beween the years? Let's say 98 - 02?
If the cam grind plays a rule on how GM programmed those values each year should be different. If they are the same it would be interesting to understand why F-bodies LS1 have different values than Corvettes.
Stefano
#2850 - 10/17/08 02:13 PM Re: Injectors offset voltage times not created equal [Re: ]
#2860 - 10/20/08 01:04 PM Re: Injectors offset voltage times not created equal [Re: teamzr1]
tici
Here the 1998 F-Body delay table, which is pretty different than the 99 and the 02
#2861 - 10/20/08 01:16 PM Re: Injectors offset voltage times not created equal [Re: ]
tici
And here the cam specs of different F and Y bodies.
Notice how the 98 and the 99 F-body have the same cam specs but completely different injectors offset.
The 97-98 injectors flow is 28.5 Lbs-Hr @ 4 bar
The 99-00 injectors flow is 26.3 Lbs-Hr @ 4 bar
Page 2 of 3 1 2 3
0 registered members (), 9 guests, and 19 spiders.
by teamzr1. 08/01/25 04:21 PM
by teamzr1. 07/30/25 12:00 PM
