Topics3,715
Posts6,904
Most Online425 Oct 19th, 2025
#2814 - 10/07/08 02:23 PM
Purpose of higher fuel pump capacity
tici
After modifying an engine for more power it's necessary to increase the capacity of the fuel system: usually bigger injectors and a bigger (or additional) fuel pump.
What is the real purpose of more pumping capacity? More flow? Or more flow AND more pressure?
I'm asking because I just had to remove a damaged fuel pump supplied with a Vortech supercharger kit. This pump is supposed to be installed in series after the stock pump located in the fuel tank.
With only the stock pump the fuel trims are now around 2% leaner than before (I was surprised to see only that little difference), so I have to assume that the purpose of the additional pump was just to ensure enough flow but not necessary more pressure. Am I right?
This is a 98 Trans Am, the injectors are Bosch 36 Lbs/h. There isn't a real pressure regulator, just an orifice in the return of the fuel line.
The supercharger is no longer installed and the car is tuned for NA.
Thanks
Stefano
#2817 - 10/08/08 11:04 AM
Re: Purpose of higher fuel pump capacity
[Re: teamzr1]
tici
Is there an optimal pressure for a fuel injector? Or just a minimal pressure? Does the pressure change the spray pattern or the dimension of the droplets?
#2819 - 10/09/08 06:38 AM
[Re: teamzr1]
tici
...as the pressure changes in regulator effects injector pressure and flow pattern What is the result of a higher / lower fuel pressure? Sure, the spray pattern is different, but what is the relationship between pressure - fuel consumption - engine cooling - valves cooling - ...? I saw your post about programming the correct Injectors offset voltage and I can imagine that fuel pressure has a similar rule Stefano
10
guests, and
10
spiders. |
Admin,
Global Mod,
