Originally Posted by teamzr1
...as the pressure changes in regulator effects injector pressure and flow pattern
What is the result of a higher / lower fuel pressure?
Sure, the spray pattern is different, but what is the relationship between pressure - fuel consumption - engine cooling - valves cooling - ...?
I saw your post about programming the correct Injectors offset voltage and I can imagine that fuel pressure has a similar rule
Stefano
