08-07-300-042: EI08323 - Intermittent Malfunction Indicator Lamp (MIL) - Check Engine Light On, Input/Output Speed Sensor Concerns, Trans Shift Concerns, Driveability Concerns, Various DTCs(Engineering Information) - (Sep 30, 2008)
Models: 2009 Chevrolet Avalanche, Corvette, Silverado, Suburban, Tahoe with 6L50, 6L80 or 6L90 Automatic Transmission (RPOs MYB, MYC or MYD)
Attention:
Proceed with this bulletin ONLY if the customer has commented about this concern AND the EI number is listed in GMVIS. If the customer has not commented about this condition or the EI does not show in GMVIS, disregard the bulletin and proceed with diagnostics found in published service information.
THIS IS NOT A RECALL -- refer to Service Bulletin 04-00-89-053B for more detail on the use of Engineering Information bulletins.
Condition
Important:
If the customer did not bring their vehicle in for this concern, DO NOT proceed with this bulletin. For all transmission repairs, if the repair action points to replacing the control solenoid valve and transmission control module, proceed with this bulletin.
Some customers may comment on an intermittent MIL/check engine light illuminated. The customer may also comment on transmission shift or driveability concerns.
Cause
GM Engineering is attempting to determine the root cause of transmission concerns caused by the control solenoid valve and transmission control module.
Engineering has a need to gather information on vehicles, DURING diagnosis and PRIOR to repair, that may exhibit this condition. As a result, this information will be used to "root cause" the customer's concern and develop/validate a field fix.
Instructions
If diagnosis points to the control solenoid valve and transmission control module as the root cause of the customer concern, before replacement please obtain the following data and contact one of the persons listed below.
• Capture or record freeze frame or fail records if a DTC is set.
• Document the diagnostics completed leading to the decision to replace the control solenoid valve and transmission control module.
