Page 2 of 3 1 2 3
#2835 - 10/14/08 12:35 PM Re: Injectors offset voltage times not created equal [Re: teamzr1]
tici
Here the results:
0% offset change (stock) => Fuel Trims = +1.73% (FTC 6-14) and +1.70% (FTC 1-19)
+10% offset change => Fuel Trims = +0.14% (FTC 6-14) and -0.91% (FTC 1-19)
-10% offset change => Fuel Trims = +3.12% (FTC 6-14) and 3.39% (FTC 1-19)
The fuel trims values are a sum of LTFT and STFT (this to give a more precide result).
I averaged the counts and not the cells, so those numbers are a weighted average and give the real pictuer of the thing.
With -10% offset something is strange... it's not too bad but it's like an old car with a compression problem. A little asleep sleep
#2836 - 10/14/08 03:46 PM Re: Injectors offset voltage times not created equal [Re: ]
In your case
#2837 - 10/15/08 12:00 AM Re: Injectors offset voltage times not created equal [Re: teamzr1]
tici
Here the results as a graph
#2839 - 10/15/08 08:05 AM Re: Injectors offset voltage times not created equal [Re: ]
I would do tuning tests with both -10 and +10 as to injector IFR table and see which one you like best.
#2840 - 10/15/08 10:09 AM Re: Injectors offset voltage times not created equal [Re: teamzr1]
tici
OK let me try.
would you try with even bigger changes? like +/- 20%?
Do you see a reason why increasing the delay time (= advancing the fuel injection) the engine reacts better?
I can't express it in numbers, but it's one of those improvements that put a smile on your face when you test drive the car.
Better fuel vaporisation?
#2846 - 10/16/08 07:20 PM Re: Injectors offset voltage times not created equal [Re: ]
#2847 - 10/17/08 01:36 AM Re: Injectors offset voltage times not created equal [Re: teamzr1]
tici
I see.
The voltage is between 13.5 and 14 depending in the electrical load (lights, defogger, fan...).
I'll probably tweak the region between 12.5 and 15 V
My version of LS1Edit can read only 97-98 programs.
Could you take a look at the differences beween the years? Let's say 98 - 02?
If the cam grind plays a rule on how GM programmed those values each year should be different. If they are the same it would be interesting to understand why F-bodies LS1 have different values than Corvettes.
Stefano
#2850 - 10/17/08 01:13 PM Re: Injectors offset voltage times not created equal [Re: ]
#2860 - 10/20/08 12:04 PM Re: Injectors offset voltage times not created equal [Re: teamzr1]
tici
Here the 1998 F-Body delay table, which is pretty different than the 99 and the 02
#2861 - 10/20/08 12:16 PM Re: Injectors offset voltage times not created equal [Re: ]
tici
And here the cam specs of different F and Y bodies.
Notice how the 98 and the 99 F-body have the same cam specs but completely different injectors offset.
The 97-98 injectors flow is 28.5 Lbs-Hr @ 4 bar
The 99-00 injectors flow is 26.3 Lbs-Hr @ 4 bar
Page 2 of 3 1 2 3
