Yes it is mounted to the frame on drivers side behind the gill panel.
3 quarts would not fit and 2 is enough ( plus the oil in the hose) for the short time it is needed.
I put the remote oil filter above the little fender panel where the AIR pump is ( below the left headlight area)
It you do not move the oil filter then just one hose needed to the sump but the stock filter to me is too small in volume and is too close to headers causing excess heat to filter
