The following calculating table allows you to see the effects in using boost to engine compression, combustion chamber flow quality, air and water temp and octane to gas as to effects of engine timing.
Change ONLY the values in the cells with the BLUE background and see how much timing would be needed to be retarded.
Worksheet table
