This is a short PE scan I made of my 98 Trans Am (stock LS1 engine). Notice the mV differece between the banks. The light blue line is the AFR measured with a WB installed just before the passanger side catalyst.
#3012 - 04/24/0905:36 PMRe: PE Oxygen sensors reading
[Re: ]
The difference of 812 mVolts and 890 is only a AFR difference of about 12.7 to 12.5 AFR so not that far off. Both sides of engine exhaust makeup rarely are equal
#3014 - 04/24/0911:28 PMRe: PE Oxygen sensors reading
[Re: teamzr1]
The common internet opinion is that the PCM stops using the VE above 4000 rpm and only goes by the MAF I personnally don't know: I never had a prouve of when the PCM uses MAF or VE.
#3015 - 04/25/0910:52 AMRe: PE Oxygen sensors reading
[Re: ]
Sorry I stated that differently then what I wanted.
Yes below 4,000 RPMs the PCM can use predicted airflow. VE is NOT normally used, it is a backup if MAF is seen as faulty or some decel conditions
#3018 - 04/27/0901:16 AMRe: PE Oxygen sensors reading
[Re: teamzr1]
There is a noise coming from one head, like a bent pushrod or a damaged lifter... maybe a weak spring. I was thinking at a relationship between the mV difference and some mechanical issue because the problem starts only after a certain RPM. OK I know: I should check a lot of other things. This engine has now 100'000 miles, been supercharged during 30'000 and I can't expect everything is still perfact.
What would you do with this engine? Just let it work as long nothing bad happens or consider a rebuild? Or buy a low milage rebuilt engine? I've never rebuilt an engine and I should buy a bunch of tools. Chances are I spend a lot of money and mess up the engine
#3020 - 04/27/0907:53 AMRe: PE Oxygen sensors reading
[Re: ]
If needed replace what you can without even taking heads off. I'd really test the fuel injectors, sparkplugs and plug wires.
#3023 - 04/27/0901:00 PMRe: PE Oxygen sensors reading
[Re: teamzr1]
Parts over here cost about 3x - 4x more than in the US, that's why I import almost everything (not a joke! I had to pay $50 for a AC belt + PCV valve)
Compression is fine for all 8 cylinders, I didn't had the chance for a leakdown test.
I'd like a new engine like the LS3 but it's not legal to install more powerful engines so in case of an accident I'm in troubles with police + insurance (not that having a blower like the last few years is better, but at least I can remove it and go back to stock in few hours).
It would be fine a rebuilt 98 engine that would fit the existing PCM + harness. Are you guys even rebuild those old engines? Or swap them wir newer ones?
#3024 - 04/27/0902:19 PMRe: PE Oxygen sensors reading
[Re: ]
#3033 - 04/30/0901:28 AMRe: PE Oxygen sensors reading
[Re: teamzr1]
Yes I was using wather/meth injection but since I removed the blower (6 months ago) and engine is otherwise stock I don't use it anymore.
Bottom end: is there a way to check main and rods bearings without removing the oil pan? Would they be really noisy if they aren't OK?
Removing the heads on a F-Body is such a pain that I'll probably prefer to drop engine + tranny. So checking for other things will be much easier.
#3034 - 04/30/0902:04 PMRe: PE Oxygen sensors reading
[Re: ]
You could still use the water/methanol even with engine NA, I have on my vette for years now. At least it would clean and then keep cylinder/valves clean as carbon buildup will induce more noise along with knock as carbon gets thicker.
#3035 - 05/01/0901:21 AMRe: PE Oxygen sensors reading
[Re: teamzr1]
Yep, at least a check and then decide if take the rest apart too. Sell the car and import a low mileage Corvette from the States is an option too (we discussed this already).
Thanks for now, I'll post more about the topic as soon I'll find out how healthy is the engine.
