Topics3,614
Posts6,712
#3011 - 04/24/09 01:11 PM PE Oxygen sensors reading
tici
This is a short PE scan I made of my 98 Trans Am (stock LS1 engine).
Notice the mV differece between the banks.
The light blue line is the AFR measured with a WB installed just before the passanger side catalyst.
Thanks for any comment
Stefano
#3012 - 04/24/09 06:36 PM Re: PE Oxygen sensors reading [Re: ]
The difference of 812 mVolts and 890 is only a AFR difference of about 12.7 to 12.5 AFR so not that far off.
Both sides of engine exhaust makeup rarely are equal
#3014 - 04/25/09 12:28 AM Re: PE Oxygen sensors reading [Re: teamzr1]
tici
The common internet opinion is that the PCM stops using the VE above 4000 rpm and only goes by the MAF crazy
I personnally don't know: I never had a prouve of when the PCM uses MAF or VE.
#3015 - 04/25/09 11:52 AM Re: PE Oxygen sensors reading [Re: ]
Sorry I stated that differently then what I wanted.
Yes below 4,000 RPMs the PCM can use predicted airflow.
VE is NOT normally used, it is a backup if MAF is seen as faulty or some decel conditions
#3018 - 04/27/09 02:16 AM Re: PE Oxygen sensors reading [Re: teamzr1]
tici
There is a noise coming from one head, like a bent pushrod or a damaged lifter... maybe a weak spring.
I was thinking at a relationship between the mV difference and some mechanical issue because the problem starts only after a certain RPM.
OK I know: I should check a lot of other things. This engine has now 100'000 miles, been supercharged during 30'000 and I can't expect everything is still perfact.
What would you do with this engine? Just let it work as long nothing bad happens or consider a rebuild? Or buy a low milage rebuilt engine? I've never rebuilt an engine and I should buy a bunch of tools. Chances are I spend a lot of money and mess up the engine cry
#3020 - 04/27/09 08:53 AM Re: PE Oxygen sensors reading [Re: ]
If needed replace what you can without even taking heads off.
I'd really test the fuel injectors, sparkplugs and plug wires.
#3023 - 04/27/09 02:00 PM Re: PE Oxygen sensors reading [Re: teamzr1]
tici
Parts over here cost about 3x - 4x more than in the US, that's why I import almost everything (not a joke! I had to pay $50 for a AC belt + PCV valve)
Compression is fine for all 8 cylinders, I didn't had the chance for a leakdown test.
I'd like a new engine like the LS3 but it's not legal to install more powerful engines so in case of an accident I'm in troubles with police + insurance (not that having a blower like the last few years is better, but at least I can remove it and go back to stock in few hours).
It would be fine a rebuilt 98 engine that would fit the existing PCM + harness. Are you guys even rebuild those old engines? Or swap them wir newer ones?
#3024 - 04/27/09 03:19 PM Re: PE Oxygen sensors reading [Re: ]
#3033 - 04/30/09 02:28 AM Re: PE Oxygen sensors reading [Re: teamzr1]
tici
Yes I was using wather/meth injection but since I removed the blower (6 months ago) and engine is otherwise stock I don't use it anymore.
Bottom end: is there a way to check main and rods bearings without removing the oil pan? Would they be really noisy if they aren't OK?
Removing the heads on a F-Body is such a pain that I'll probably prefer to drop engine + tranny. So checking for other things will be much easier.
#3034 - 04/30/09 03:04 PM Re: PE Oxygen sensors reading [Re: ]
You could still use the water/methanol even with engine NA, I have on my vette for years now.
At least it would clean and then keep cylinder/valves clean as carbon buildup will induce more noise along with knock as carbon gets thicker.
