#3020 - 04/27/0907:53 AMRe: PE Oxygen sensors reading
[Re: ]
Joined: Dec 2000 Posts: 6,036teamzr1 Owner - Pays the bills
If needed replace what you can without even taking heads off. I'd really test the fuel injectors, sparkplugs and plug wires.
