Topics3,715
Posts6,904
Most Online425 Oct 19th, 2025
#3053 - 05/13/09 10:18 AM
Body Chassis DTC Error Codes
B0001 GM PCM Discrete Input Speed Signal Error B0004 GM PCM Discrete Input Speed Signal Not Present B0005 GM In Park Switch Circuit Malfunction B0016 Corvette Right Front/Passenger Frontal Deployment Loop (Stage 1) Circuit B0016 GM RF/Passenger Frontal Deployment Loop (Single Stage or Stage 1) Resistance Low B0017 Corvette Right Front/Passenger Frontal Deployment Loop (Stage 1) Circuit B0017 GM RF/Passenger Frontal Deployment Loop (Single Stage or Stage 1) Open B0018 Corvette Right Front/Passenger Frontal Deployment Loop (Stage 1) Circuit B0018 GM RF/Passenger Frontal Deployment Loop (Single Stage or Stage 1) Short to Ground/Voltage Out of Range B0022 Corvette Left Front/Driver Frontal Deployment Loop (Stage 1) Circuit B0022 GM LF/Driver Frontal Deployment Loop (Single Stage or Stage 1) Resistance Low B0024 Corvette Left Front/Driver Frontal Deployment Loop (Stage 1) Circuit B0024 GM LF/Driver Frontal Deployment Loop (Single Stage or Stage 1) Short to Ground/Voltage Out of Range B0026 Corvette Left Front/Driver Frontal Deployment Loop (Stage 1) Circuit B0026 GM LF/Driver Frontal Deployment Loop (Single Stage or Stage 1) Open B0028 GM RF/Passenger Side Deployment Loop Resistance Low B0029 GM RF/Passenger Side Deployment Loop Open B0030 GM RF/Passenger Side Deployment Loop Short to Ground/Voltage Out of Range B0035 GM ADS Closed/Shorted to Ground B0036 GM ADS Open/Missing/Shorted to Battery B0037 GM AUX switch closed/shorted to ground B0038 GM AUX switch open/shorted to battery B0040 GM LF/Driver Side Deployment Loop Resistance Low B0041 GM LF/Driver Side Deployment Loop Open B0045 GM LF Side Deploy Loop Short to Ground/Voltage Out of Range B0051 Corvette Deployment Commanded B0051 GM Deployment Commanded B0053 Corvette Deployment Commanded with Loop Malfunctions Present B0053 GM Deployment Commanded with Loop Malfunctions Present B0057 GM RF/Passenger Pretensioner Deployment Loop Resistance Low B0058 GM RF/Passenger Pretensioner Deployment Loop Open B0059 GM RF/Passenger Pretensioner Deployment Loop Short to Ground/Voltage Out of Range B0064 GM LF/Driver Pretensioner Deployment Loop Resistance Low B0065 GM LF/Driver Pretensioner Deployment Loop Open B0066 GM LF/Driver Pretensioner Deployment Loop Short to Ground/Voltage Out of Range B0073 GM Supplemental Deployment Loop #1 Resistance Low B0074 GM Supplemental Deployment Loop #1 Open B0075 GM Supplemental Deployment Loop #1 Short to Ground/Voltage Out of Range B0077 GM LF/Driver SIS Malfunction B0078 GM RF/Passenger SIS Malfunction B0079 GM Incorrect LF/Driver SIS Installed B0080 GM Discard LF/Driver SIS B0081 GM Incorrect RF/Passenger SIS Installed B0082 GM Discard RF/Passenger SIS B0086 GM Supplemental Deployment Loop #2 Resistance Low B0087 GM Supplemental Deployment Loop #2 Open B0088 GM Supplemental Deployment Loop #2 Short to Ground/Voltage Out of Range B0090 Corvette Active Switch Voltage Out of Range B0090 GM Active switch voltage out of range B0091 Corvette Active Switch: Wrong State B0091 GM Active switch: wrong state B0092 GM PPS passenger detection error B0093 GM PPS/CPS self-test malfunction B0094 GM CPS childseat detection error B0095 GM SDM-PPS/CPS mismatch malfunction B0126 GM Right Panel Discharge Temperature Fault B0131 GM Right Heater Discharge Temperature Fault B0159 GM Outside Air Temperature Sensor Circuit Range/Performance B0164 GM Passenger Compartment Temperature Sensor #1 (Single Sensor or LH) Circuit Range/Performance B0169 GM In-car Temp Sensor Failure (passenger -not used) B0174 GM Output Air Temperature Sensor #1 (Upper; Single or LH) Circuit Range/Performance B0179 GM Output Air Temperature Sensor #2 (Lower; Single or LH) Circuit Range/Performance B0184 GM Solar Load Sensor #1 CKT Range B0189 GM Solar Load Sensor #2 CKT Range B0248 GM Mode Door Inoperative Error B0249 GM Heater/Defrost/AC Door Range Error B0268 GM A/I Door Inoperative Error B0269 GM Air Inlet Door Range Error B0332 Corvette Outside Air Temp Sensor Short to Ground B0333 Corvette Outside Air Temperature Sensor Open B0337 Corvette Inside Air Temp Sensor Short to GND B0338 Corvette Inside Air Temperature Sensor Open B0348 Corvette Sunload Temperature Sensor Open B0361 Corvette Left Actuator Feedback Short to GND B0363 Corvette Left Actuator Feedback Open B0365 Corvette Right Actuator Feedback Short to GND B0367 Corvette Right Actuator Feedback Open B0408 GM Temperature Control #1 (Main/Front) Circuit Malfunction B0409 GM Air Mix Door #1 Range Error B0419 GM Air Mix Door #2 Range Error B0423 GM Air Mix Door #2 Inoperative Error B0428 GM Air Mix Door #3 Inoperative Error B0429 GM Temperature Control #3 Rear Circuit Range/Performance B0432 Corvette Rear Defogger Relay Circuit B0433 Corvette Rear Defogger Relay Circuit B0441 Corvette Left Actuator Out of Range B0446 Corvette Right Actuator Out of Range B0502 Corvette RH DRL Relay Circuit B0503 Corvette RH DRL Relay Circuit B0507 Corvette LH DRL Relay Circuit B0508 Corvette LH DRL Relay Circuit B0510 GM RH Panel Discharge Temp Sensor Failure B0515 GM RH Heater Discharge Temp Sensor Failure B0516 Corvette Speedometer Signal Circuit Malfunction B0520 GM Rear Discharge Temp Sensor Failure B0521 Corvette Tachometer Signal Circuit Malfunction B0530 GM Fuel Level Sensor Stuck B0532 GM Fuel Sensor Shorted To Ground B0533 GM Fuel Sensor Open/Shorted To B+ B0605 Corvette BCM Internal Memory Malfunction B0688 GM Security System Indicator Circuit High B0768 GM Service Indicator Circuit High B0846 Corvette Battery 2 Out of Range B0846 Corvette or B0851 Battery Out of Range B0846 GM +5 Volt Reference Out of Range B0851 Corvette Battery 1 Out of Range B0856 Corvette +5 Volt Reference Out of Range B0856 GM Battery 2 Out of Range B1000 Corvette ECU Malfunction B1000 GM ECU Malfunction B1001 Corvette Option Configuration Error B1001 GM Option Configuration Error B1004 GM Keep Alive Memory (KAM) B1007 GM EEPROM Write Error B1009 GM EEPROM Checksum Error B1013 GM ROM Checksum Error B1014 GM Program ROM Checksum Error B1015 GM Passenger Deploy. Loop Resistance High B1016 GM Passenger Deployment Loop Resistance Low B1017 GM Passenger Deployment Loop Open B1018 GM Passenger Deployment Loop Short to GND B1019 GM Passenger Deploy. Loop Short to Voltage B1021 GM Driver Deployment Loop Resistance High B1022 GM Driver Deployment Loop Resistance Low B1024 GM Driver Deployment Loop Short to Ground B1025 GM Driver Deployment Loop Short to Voltage B1026 GM Driver Deployment Loop Open B1035 GM Discr. Sensor Closed or Short to GND B1036 GM Discr. Sensor Open or Short to Voltage B1051 GM Frontal Air Bag and Preten Deployment B1053 GM Deployment Commanded w/Loop Malfunction B1054 GM Infl Rst IP Module Switch CKT Failure B1061 GM Lamp Circuit Failure B1071 GM Internal SDM Failure B1115 GM Passenger Deploy. Loop Resistance High B1116 GM Passenger Deploy. Loop Resistance Low B1117 GM Passenger Deployment Loop Open B1121 GM Driver Deployment Loop Resistance High B1122 GM Driver Deployment Loop Resistance Low B1124 GM Driver/Pass. Deploy. Loop Short to GND B1125 GM Driver/Pass Deploy Loop Short to Voltage B1126 GM Driver Deployment Loop Open B1131 GM Pass. Pretensioner Loop Resistance High B1132 GM Pass. Pretensioner Loop Resistance Low B1134 GM Passenger Pretensioner Loop Open B1135 GM Discr. Sensor Closed or Short to GND B1136 GM Discr. Sensor Open or Short to Voltage B1141 GM Driver Pretensioner Loop Resistance High B1142 GM Driver Pretens. Deploy. Loop Res. Low B1144 GM Driver/Pass Pretens. Loop Short to GND B1145 GM Driver/Pass Pretens. Loop Short to Volt B1146 GM Driver Pretensioner Loop Open B1147 GM Driver Side Air Bag System Malfunction B1148 GM Pass. Side Air Bag System Malfunction B1151 GM Deployment Commanded - Frontal B1152 GM Data Area Full B1153 GM Deployment Commanded w/Loop Malfunction B1155 GM SDM Calibration Mismatch B1159 GM Loss of Serial Data-Key Not Received B1160 GM Loss of Serial Data - VIN Not Received B1161 GM Lamp Circuit Failure B1163 GM Loss of Serial Data-No Lamp Response B1171 GM Internal SDM Failure B1200 Generic Climate Control Pushbutton Circuit Failure B1201 Generic Fuel Sender Circuit Failure B1202 Generic Fuel Sender Circuit Open B1203 Generic Fuel Sender Circuit Short To Battery B1204 Generic Fuel Sender Circuit Short To Ground B1205 Generic EIC Switch-1 Assembly Circuit Failure B1206 Generic EIC Switch-1 Assembly Circuit Open B1207 Generic EIC Switch-1 Assembly Circuit Short To Battery B1208 Generic EIC Switch-1 Assembly Circuit Short To Ground B1209 Generic EIC Switch-2 Assembly Circuit Failure B1210 Generic EIC Switch-2 Assembly Circuit Open B1211 Generic EIC Switch-2 Assembly Circuit Short To Battery B1212 Generic EIC Switch-2 Assembly Circuit Short To Ground B1213 Generic Anti-Theft Number of Programmed Keys Is Below Minimum B1214 Generic Running Board Lamp Circuit Failure B1215 Generic Running Board Lamp Circuit Short to Battery B1216 Generic Emergency & Road Side Assistance Switch Circuit Short to Ground B1217 Generic Horn Relay Coil Circuit Failure B1218 Generic Horn Relay Coil Circuit Short to Vbatt B1219 Generic Fuel Tank Pressure Sensor Circuit Failure B1220 Generic Fuel Tank Pressure Sensor Circuit Open B1222 Generic Fuel Temperature Sensor #1 Circuit Failure B1223 Generic Fuel Temperature Sensor #1 Circuit Open B1224 Generic Fuel Temperature Sensor #1 Circuit Short to Battery B1225 Generic Fuel Temperature Sensor #1 Circuit Short to Ground B1226 Generic Fuel Temperature Sensor #2 Circuit Failure B1227 Generic Fuel Temperature Sensor #2 Circuit Open B1228 Generic Fuel Temperature Sensor #2 Circuit Short to Battery B1229 Generic Fuel Temperature Sensor #2 Circuit Short to Ground B1231 Generic Longitudinal Acceleration Threshold Exceeded B1232 Generic See Manufacturer B1233 Generic Glass Break Sensor Failure B1234 Generic Mirror Switch Invalid Code B1235 Generic Window Feedback Failure B1236 Generic Window Feedback Loss of Signal B1237 Generic Window Feedback Out of Range B1238 Generic Over Temperature Fault B1239 Generic Air Flow Blend Door Driver Circuit Failure B1240 Generic Wiper Washer Rear Pump Relay Circuit Failure B1241 Generic Wiper Washer Rear Pump Relay Circuit Short to Battery B1242 Generic Air Flow Recirculation Door Driver Circuit Failure B1243 Generic Express Window Down Switch Circuit Short to Battery B1244 Generic Wiper Rear Motor Run Relay Circuit Failure B1245 Generic Wiper Rear Motor Run Relay Circuit Short to Battery B1245 GM CD Changer Not Responding B1246 Generic Dim Panel Potentiometer Switch Circuit Failure B1247 Generic Panel Dim Switch Circuit Open B1248 Generic Passenger's Seatback Autoglide Rearward Switch Circuit Short to Ground B1249 Generic Blend Door Failure B1250 Generic Air Temperature Internal Sensor Circuit Failure B1251 Generic Air Temperature Internal Sensor Circuit Open B1252 Generic Air Temperature Internal Sensor Circuit Short To Battery B1253 Generic Air Temperature Internal Sensor Circuit Short To Ground B1254 Generic Air Temperature External Sensor Circuit Failure B1255 Generic Air Temperature External Sensor Circuit Open B1256 Generic Air Temperature External Sensor Circuit Short To Battery B1257 Generic Air Temperature External Sensor Circuit Short To Ground B1258 Generic Solar Radiation Sensor Circuit Failure B1259 Generic Solar Radiation Sensor Circuit Open B1260 Generic Solar Radiation Sensor Circuit Short To Battery B1261 Generic Solar Radiation Sensor Circuit Short To Ground B1262 Generic Servo Motor Defrost Circuit Failure B1263 Generic Servo Motor Vent Circuit Failure B1264 Generic Servo Motor Foot Circuit Failure B1265 Generic Servo Motor Coolair Bypass Circuit Failure B1266 Generic Servo Motor Airintake Left Circuit Failure B1267 Generic Servo Motor Airintake Right Circuit Failure B1268 Generic Servo Motor Potentiometer Defrost Circuit Failure B1269 Generic Servo Motor Potentiometer Defrost Circuit Open B1270 Generic Servo Motor Potentiometer Defrost Circuit Short To Battery B1271 Generic Servo Motor Potentiometer Defrost Circuit Short To Ground B1271 GM Theft Lock Enabled B1272 Generic Servo Motor Potentiometer Vent Circuit Failure B1273 Generic Servo Motor Potentiometer Vent Circuit Open B1274 Generic Servo Motor Potentiometer Vent Circuit Short To Battery B1275 Generic Servo Motor Potentiometer Vent Circuit Short To Ground B1276 Generic Servo Motor Potentiometer Foot Circuit Failure B1277 Generic Servo Motor Potentiometer Foot Circuit Open B1278 Generic Servo Motor Potentiometer Foot Circuit Short To Battery B1279 Generic Servo Motor Potentiometer Foot Circuit Short To Ground B1280 Generic Servo Motor Potentiometer Coolair Circuit Failure B1281 Generic Servo Motor Potentiometer Coolair Circuit Open B1282 Generic Servo Motor Potentiometer Coolair Circuit Short To Battery B1283 Generic Servo Motor Potentiometer Coolair Circuit Short To Ground B1284 Generic Servo Motor Potentiometer Airintake Left Circuit Failure B1285 Generic Servo Motor Potentiometer Airintake Left Circuit Open B1286 Generic Servo Motor Potentiometer Airintake Left Circuit Short To Battery B1287 Generic Servo Motor Potentiometer Airintake Left Circuit Short To Ground B1288 Generic Servo Motor Potentiometer Airintake Right Circuit Failure B1289 Generic Servo Motor Potentiometer Airintake Right Circuit Open B1290 Generic Servo Motor Potentiometer Airintake Right Circuit Short To Battery B1291 Generic Servo Motor Potentiometer Airintake Right Circuit Short To Ground B1292 Generic Battery Power Relay Circuit Failure B1293 Generic Battery Power Relay Circuit Open B1294 Generic Battery Power Relay Circuit Short To Battery B1295 Generic Battery Power Relay Circuit Short To Ground B1296 Generic Power Supply Sensor Circuit Failure B1297 Generic Power Supply Sensor Circuit Open B1298 Generic Power Supply Sensor Circuit Short To Battery B1299 Generic Power Supply Sensor Circuit Short To Ground B1300 Generic Power Door Lock Circuit Failure B1301 Generic Power Door Lock Circuit Open B1302 Generic Accessory Delay Relay Coil Circuit Failure B1303 Generic Accessory Delay Relay Coil Circuit Open B1304 Generic Accessory Delay Relay Coil Circuit Short To Battery B1305 Generic Accessory Delay Relay Coil Circuit Short To Ground B1306 Generic Oil Level Switch Circuit Open B1307 Generic Oil Level Switch Circuit Short To Battery B1308 Generic Oil Level Switch Circuit Short To Ground B1309 Generic Power Door Lock Circuit Short To Ground B1310 Generic Power Door Unlock Circuit Failure B1310 GM Ambient Air Temperature Sensor Failure B1311 Generic Power Door Unlock Circuit Open B1311 GM Outside Air Temp Sensor Short Circuit B1312 Generic Lamp Headlamp Input Circuit Short To Battery B1312 GM High Side Temp Sensor Open Circuit B1313 Generic Battery Saver Relay Coil Circuit Failure B1313 GM High Side Temp Sensor Short Circuit B1314 Generic Battery Saver Relay Coil Circuit Open B1314 GM Evaporator Inlet Temp Sensor Open CKT B1315 Generic Battery Saver Relay Coil Circuit Short To Battery B1315 GM Evaporator Inlet Temp Sensor Short CKT B1316 Generic Battery Saver Relay Coil Circuit Short To Ground B1316 GM In Car Temperature Sensor Open Circuit B1317 Generic Battery Voltage High B1317 GM In Car Air Temperature Sensor B1318 Generic Battery Voltage Low B1318 GM LH Sun Load Sensor Fault B1319 Generic Driver Door Ajar Circuit Failure B1319 GM Sunload Sensor Short Circuit B1320 Generic Driver Door Ajar Circuit Open B1321 Generic Driver Door Ajar Circuit Short To Battery B1321 GM A/C Low Side Temperature Sensor Fault B1322 Generic Driver Door Ajar Circuit Short To Ground B1323 Generic Door Ajar Lamp Circuit Failure B1324 Generic Door Ajar Lamp Circuit Open B1324 GM A/C Refrigerant Overpressure B1325 Generic Door Ajar Lamp Circuit Short To Battery B1326 Generic Door Ajar Lamp Circuit Short To Ground B1327 Generic Passenger Door Ajar Circuit Failure B1327 GM Device Power Circuit Low B1328 Generic Passenger Door Ajar Circuit Open B1328 GM Device Power Circuit High B1328 GM RH Sun Load Sensor Fault B1329 Generic Passenger Door Ajar Circuit Short To Battery B1330 Generic Passenger Door Ajar Circuit Short To Ground B1330 GM Left A/C Discharge Sensor Fault B1331 Generic Decklid Ajar Rear Door Circuit Failure B1331 GM Right A/C Discharge Sensor Fault B1332 Generic Decklid Ajar Rear Door Circuit Open B1332 GM Left Heater Discharge Sensor Fault B1333 Generic Decklid Ajar Rear Door Circuit Short To Battery B1333 GM Right Heater Discharge Sensor Fault B1334 Generic Decklid Ajar Rear Door Circuit Short To Ground B1335 Generic Door Ajar RR Circuit Failure B1336 Generic Door Ajar RR Circuit Open B1337 Generic Door Ajar RR Circuit Short To Battery B1338 Generic Door Ajar RR Circuit Short To Ground B1339 Generic Chime Input Request Circuit Short To Battery B1340 Generic Chime Input Request Circuit Short To Ground B1340 GM Air Mix Door One Movement Fault B1341 Generic Power Door Unlock Circuit Short To Ground B1341 GM Air Mix Door Two Movement Fault B1342 Generic ECU Is Defective B1343 Generic Heated Backlite Input Circuit Failure B1343 GM Air Inlet Door Movement Fault B1344 Generic Heated Backlite Input Circuit Open B1344 GM HTR/DEF/AC Door Movement Fault B1345 Generic Heated Backlite Input Circuit Short To Ground B1346 Generic Heated Backlite Input Circuit Short To Battery B1347 Generic Heated Backlite Relay Circuit Failure B1347 GM Very Low A/C Refrigerant Warning B1348 Generic Heated Backlite Relay Circuit Open B1348 GM Very Low A/C Refrigerant Pressure B1349 Generic Heated Backlite Relay Short To Battery B1350 Generic Heated Backlite Relay Short To Ground B1350 GM Engine Coolant Over-Temperature B1351 Generic Ignition Key-In Circuit Short To Battery B1352 Generic Ignition Key-In Circuit Failure B1353 Generic Ignition Key-In Circuit Open B1354 Generic Ignition Key-In Circuit Short To Ground B1355 Generic Ignition Run Circuit Failure B1356 Generic Ignition Run Circuit Open B1357 Generic Ignition Run Circuit Short To Battery B1358 Generic Ignition Run Circuit Short To Ground B1359 Generic Ignition Run/Acc Circuit Failure B1360 Generic Ignition Run/Acc Circuit Open B1361 Generic Ignition Run/Acc Circuit Short To Battery B1362 Generic Ignition Run/Acc Circuit Short To Ground B1363 Generic Ignition Start Circuit Failure B1364 Generic Ignition Start Circuit Open B1365 Generic Ignition Start Circuit Short To Battery B1366 Generic Ignition Start Circuit Short To Ground B1367 Generic Ignition Tach Circuit Failure B1368 Generic Ignition Tach Circuit Open B1369 Generic Ignition Tach Circuit Short To Battery B1370 Generic Ignition Tach Circuit Short To Ground B1371 Generic Illuminated Entry Relay Circuit Failure B1372 Generic Illuminated Entry Relay Circuit Open B1373 Generic Illuminated Entry Relay Short To Battery B1374 Generic Illuminated Entry Relay Short To Ground B1375 Generic Oil Change Lamp Circuit Open B1376 Generic Oil Change Lamp Circuit Short To Battery B1377 Generic Oil Change Lamp Circuit Failure B1378 Generic Oil Change Lamp Circuit Short To Ground B1379 Generic Oil Change Reset Button Circuit Short To Ground B1380 Generic Oil Change Reset Button Circuit Failure B1381 Generic Oil Change Reset Button Circuit Open B1382 Generic Oil Change Reset Button Circuit Short To Battery B1383 Generic Oil Level Lamp Circuit Short To Battery B1384 Generic Oil Level Lamp Circuit Failure B1385 Generic Oil Level Lamp Circuit Open B1386 Generic Oil Level Lamp Circuit Short To Ground B1387 Generic Oil Temperature Sensor Circuit Open B1388 Generic Oil Temperature Sensor Circuit Short To Battery B1389 Generic Oil Temperature Sensor Circuit Failure B1390 Generic Oil Temperature Sensor Circuit Short To Ground B1390 GM Device Voltage Reference Input CKT Malf B1391 Generic Oil Level Switch Circuit Failure B1392 Generic Power Door Memory Lock Relay Circuit Failure B1393 Generic Power Door Memory Lock Relay Circuit Open B1394 Generic Power Door Memory Lock Relay Circuit Short To Battery B1395 Generic Power Door Memory Lock Relay Circuit Short To Ground B1396 Generic Power Door Lock Circuit Short To Battery B1396 GM Device Voltage Reference Output 1 Circuit Range Performance B1397 Generic Power Door Unlock Circuit Short To Battery B1398 Generic Driver Power Window One Touch Window Relay Circuit Failure B1399 Generic Driver Power Window One Touch Window Relay Circuit Open B1399 GM Loss of KDD Communications B1400 Generic Driver Power Window One Touch Window Relay Circuit Short To Battery B1401 Generic Driver Power Window One Touch Window Relay Circuit Short To Ground B1402 Generic Driver Power Window Down Switch Circuit Failure B1403 Generic Driver Power Window Up Switch Circuit Failure B1404 Generic Driver Power Window Down Circuit Open B1405 Generic Driver Power Window Down Circuit Short To Battery B1406 Generic Driver Power Window Down Circuit Short To Ground B1407 Generic Driver Power Window Up Circuit Open B1408 Generic Driver Power Window Up Circuit Short To Battery B1409 Generic Driver Power Window Up Circuit Short To Ground B1410 Generic Driver Power Window Motor Circuit Failure B1411 Generic Driver Power Window Motor Circuit Open B1412 Generic Driver Power Window Motor Circuit Short To Battery B1413 Generic Driver Power Window Motor Circuit Short To Ground B1414 Generic Power Window LR Motor Circuit Failure B1415 Generic Power Window LR Motor Circuit Open B1416 Generic Power Window LR Motor Circuit Short To Battery B1417 Generic Power Window LR Motor Circuit Short To Ground B1418 Generic Passenger Power Window Motor Circuit Failure B1419 Generic Passenger Power Window Motor Circuit Open B1420 Generic Passenger Power Window Motor Circuit Short To Battery B1421 Generic Passenger Power Window Motor Circuit Short To Ground B1422 Generic Power Window RR Motor Circuit Failure B1422 GM Device Power Moding Malfunction B1423 Generic Power Window RR Motor Circuit Open B1424 Generic Power Window RR Motor Circuit Short To Battery B1425 Generic Power Window RR Motor Circuit Short To Ground B1426 Generic Lamp Seat Belt Circuit Short To Battery B1427 Generic Lamp Seat Belt Circuit Open B1428 Generic Lamp Seat Belt Circuit Failure B1429 Generic Lamp Seat Belt Circuit Short To Ground B1430 Generic Seat Belt Switch Circuit Short To Ground B1431 Generic Wiper Brake/Run Relay Circuit Failure B1432 Generic Wiper Brake/Run Relay Circuit Short To Battery B1433 Generic Wiper Brake/Run Relay Circuit Short To Ground B1434 Generic Wiper Hi/Low Speed Relay Coil Circuit Failure B1435 Generic Wiper Hi/Low Speed Relay Coil Circuit Open B1436 Generic Wiper Hi/Low Speed Relay Coil Circuit Short To Battery B1437 Generic Wiper Hi/Low Speed Relay Coil Circuit Short To Ground B1438 Generic Wiper Mode Select Switch Circuit Failure B1438 GM IPC High Voltage Output Overcurrent to IPM B1439 Generic Wiper Mode Select Switch Circuit Open B1440 Generic Wiper Mode Select Switch Circuit Short To Battery B1441 Generic Wiper Mode Select Switch Circuit Short To Ground B1442 Generic Door Handle Switch Circuit Failure B1443 Generic Door Handle Switch Circuit Open B1444 Generic Door Handle Switch Circuit Short To Battery B1445 Generic Door Handle Switch Circuit Short To Ground B1446 Generic Wiper Park Sense Circuit Failure B1447 Generic Wiper Park Sense Circuit Open B1448 Generic Wiper Park Sense Circuit Short To Battery B1449 Generic Wiper Park Sense Circuit Short To Ground B1450 Generic Wiper Wash/Delay Switch Circuit Failure B1451 Generic Wiper Wash/Delay Switch Circuit Open B1452 Generic Wiper Wash/Delay Switch Circuit Short To Battery B1453 Generic Wiper Wash/Delay Switch Circuit Short To Ground B1454 Generic Wiper Washer Fluid Lamp Circuit Failure B1455 Generic Wiper Washer Fluid Lamp Circuit Open B1456 Generic Wiper Washer Fluid Lamp Circuit Short To Battery B1457 Generic Wiper Washer Fluid Lamp Circuit Short To Ground B1458 Generic Wiper Washer Pump Motor Relay Circuit Failure B1459 Generic Wiper Washer Pump Motor Relay Coil Circuit Open B1460 Generic Wiper Washer Pump Motor Relay Coil Circuit Short To Battery B1461 Generic Wiper Washer Pump Motor Relay Coil Circuit Short To Ground B1462 Generic Seat Belt Switch Circuit Failure B1463 Generic Seat Belt Switch Circuit Open B1464 Generic Seat Belt Switch Circuit Short To Battery B1465 Generic Wiper Brake/Run Relay Circuit Open B1466 Generic Wiper Hi/Low Speed Not Switching B1467 Generic Wiper Hi/Low Speed Circuit Motor Short To Battery B1468 Generic Chime Input Request Circuit Failure B1469 Generic Chime Input Request Circuit Open B1470 Generic Lamp Headlamp Input Circuit Failure B1471 Generic Lamp Headlamp Input Circuit Open B1472 Generic Lamp Headlamp Input Circuit Short To Ground B1473 Generic Wiper Low Speed Circuit Motor Failure B1474 Generic Battery Saver Power Relay Circuit Short To Battery B1475 Generic Accessory Delay Relay Contact Short To Battery B1476 Generic Wiper High Speed Circuit Motor Failure B1477 Generic Wiper Hi/Low Circuit Motor Short To Ground B1478 Generic Power Window One Touch Up/Down Activated Simultaneously B1479 Generic Wiper Washer Fluid Level Sensor Circuit Failure B1480 Generic Wiper Washer Fluid Level Sensor Circuit Open B1481 Generic Wiper Washer Fluid Level Sensor Circuit Short To Battery B1482 Generic Wiper Washer Fluid Level Sensor Circuit Short To Ground B1483 Generic Brake Pedal Input Circuit Failure B1484 Generic Brake Pedal Input Open Circuit B1485 Generic Brake Pedal Input Circuit Battery Short B1486 Generic Brake Pedal Input Circuit Ground Short B1487 Generic Door Handle Right Front Circuit Failure B1488 Generic Door Handle Right Front Circuit Open B1489 Generic Door Handle Right Front Short To Battery B1490 Generic Door Handle Right Front Short To Ground B1491 Generic Ignition Cylinder Sensor Circuit Failure B1492 Generic Ignition Cylinder Sensor Open Circuit B1493 Generic Ignition Cylinder Sensor Battery Short B1494 Generic Ignition Cylinder Sensor Ground Short B1495 Generic Decklid Punch-Out Sensor Circuit Failure B1496 Generic Decklid Punch-Out Sensor Open Circuit B1497 Generic Decklid Punch-Out Sensor Battery Short B1498 Generic Decklid Punch-Out Sensor Ground Short B1499 Generic Lamp Turn Signal Left Circuit Failure B1500 Generic Lamp Turn Signal Left Circuit Open B1501 Generic Lamp Turn Signal Left Circuit Short To Battery B1502 Generic Lamp Turn Signal Left Circuit Short To Ground B1503 Generic Lamp Turn Signal Right Circuit Failure B1504 Generic Lamp Turn Signal Right Circuit Open B1505 Generic Lamp Turn Signal Right Circuit Short To Battery B1506 Generic Lamp Turn Signal Right Circuit Short To Ground B1507 Generic Flash To Pass Switch Circuit Failure B1508 Generic Flash To Pass Switch Circuit Open B1509 Generic Flash To Pass Switch Circuit Short To Battery B1510 Generic Flash To Pass Switch Circuit Short To Ground B1511 Generic Driver Door Handle Circuit Failure B1512 Corvette B1537 Driver Information Center (DIC) Switch Circuit B1512 Generic Driver Door Handle Circuit Open B1513 Generic Driver Door Handle Circuit Short To Battery B1513 GM Charging System Volts Low B1514 Generic Driver Door Handle Circuit Short To Ground B1514 GM Charging System Volts High B1515 Generic Seat Driver Occupied Switch Circuit Failure B1516 Generic Seat Driver Occupied Switch Circuit Open B1517 Generic Seat Driver Occupied Switch Circuit Short To Battery B1518 Generic Seat Driver Occupied Switch Circuit Short To Ground B1519 Generic Hood Switch Circuit Failure B1520 Generic Hood Switch Circuit Open B1521 Generic Hood Switch Circuit Short To Battery B1522 Generic Hood Switch Circuit Short To Ground B1523 Generic Keyless Entry Circuit Failure B1524 Generic Keyless Entry Circuit Open B1525 Generic Keyless Entry Circuit Short To Battery B1526 Generic Keyless Entry Circuit Short To Ground B1527 Generic Memory Set Switch Circuit Failure B1528 Generic Memory Set Switch Circuit Open B1529 Generic Memory Set Switch Circuit Short To Battery B1530 Generic Memory Set Switch Circuit Short To Ground B1531 Generic Memory 1 Switch Circuit Failure B1532 Generic Memory 1 Switch Circuit Open B1533 Generic Memory 1 Switch Circuit Short To Battery B1534 Generic Memory 1 Switch Circuit Short To Ground B1535 Generic Memory 2 Switch Circuit Failure B1536 Generic Memory 2 Switch Circuit Open B1537 Generic Memory 2 Switch Circuit Short To Battery B1538 Generic Memory 2 Switch Circuit Short To Ground B1539 Generic Mirror Driver Switch Assembly Circuit Failure B1540 Generic Mirror Driver Switch Assembly Circuit Open B1541 Generic Mirror Driver Switch Assembly Circuit Short To Battery B1542 Corvette Oil Temperature Circuit Short to Ground B1542 Generic Mirror Driver Switch Assembly Circuit Short To Ground B1543 Corvette Oil Temperature Circuit Open B1543 Generic Seat Direction Switch Assembly Circuit Failure B1544 Generic Seat Direction Switch Assembly Circuit Open B1545 Generic Seat Direction Switch Assembly Circuit Short To Battery B1546 Generic Seat Direction Switch Assembly Circuit Short To Ground B1547 Generic Power Window Master Circuit Failure B1548 Generic Power Window Master Circuit Open B1549 Generic Power Window Master Circuit Short To Battery B1550 Generic Power Window Master Circuit Short To Ground B1551 Generic Decklid Release Circuit Failure B1552 Generic Decklid Release Circuit Open B1552 GM Keep Alive Memory (KAM) Error B1553 Generic Decklid Release Circuit Short To Battery B1554 Generic Decklid Release Circuit Short To Ground B1555 Generic Ignition Run/Start Circuit Failure B1556 Generic Ignition Run/Start Circuit Open B1556 GM IPC EEPROM Odo/Configuration Error B1557 Generic Ignition Run/Start Circuit Short To Battery B1557 GM EEPROM Calibration Error B1558 Generic Ignition Run/Start Circuit Short To Ground B1558 GM BCM EPROM Checksum Error B1559 Generic Door Lock Cylinder Circuit Failure B1560 Generic Door Lock Cylinder Circuit Open B1561 Generic Door Lock Cylinder Circuit Short To Battery B1562 Generic Door Lock Cylinder Circuit Short To Ground B1563 Generic Door Ajar Circuit Failure B1564 Generic Door Ajar Circuit Open B1565 Generic Door Ajar Circuit Short To Battery B1566 Generic Door Ajar Circuit Short To Ground B1567 Generic Lamp Headlamp High-Beam Circuit Failure B1568 Generic Lamp Headlamp High-Beam Circuit Open B1569 Generic Lamp Headlamp High-Beam Circuit Short To Battery B1570 Generic Lamp Headlamp High-Beam Circuit Short To Ground B1571 Generic Door Ajar LR Circuit Failure B1572 Generic Door Ajar LR Circuit Open B1573 Generic Door Ajar LR Circuit Short To Battery B1574 Generic Door Ajar LR Circuit Short To Ground B1575 Generic Lamp Park Input Circuit Failure B1576 Generic Lamp Park Input Circuit Open B1577 Generic Lamp Park Input Circuit Short To Battery B1578 Generic Lamp Park Input Circuit Short To Ground B1579 Generic Dim Panel Increase Input Circuit Failure B1580 Generic Dim Panel Increase Input Circuit Open B1581 Generic Dim Panel Increase Input Circuit Short To Battery B1582 Generic Dim Panel Increase Input Circuit Short To Ground B1583 Generic Dim Panel Decrease Input Circuit Failure B1584 Generic Dim Panel Decrease Input Circuit Open B1585 Generic Dim Panel Decrease Input Circuit Short To Battery B1586 Generic Dim Panel Decrease Input Circuit Short To Ground B1586 GM Mirror Horiz. Pos Sensor-Out of Range/Open B1587 Generic Autolamp Delay Increase Circuit Failure B1588 Generic Autolamp Delay Increase Circuit Open B1589 Generic Autolamp Delay Increase Circuit Short To Battery B1590 Generic Autolamp Delay Increase Circuit Short To Ground B1591 Generic Autolamp Delay Decrease Circuit Failure B1591 GM Mirror Vert. Pos Sensor-Out of Range/Open B1592 Generic Autolamp Delay Decrease Circuit Open B1593 Generic Autolamp Delay Decrease Circuit Short To Battery B1594 Generic Autolamp Delay Decrease Circuit Short To Ground B1595 Generic Ignition Switch Illegal Input Code B1596 Generic Service Continuous Codes B1597 Generic Driver's Seat Seatback Autoglide Forward Switch Circuit Short to Ground B1598 Generic Driver's Seat Seatback Autoglide Rearward Switch Circuit Short to Ground B1599 Generic Passenger's Seatback Autoglide Forward Switch Circuit Short to Ground B1600 Generic PATS Ignition Key Transponder Signal Is Not Received B1601 Generic PATS Received Incorrect Key-Code From Ignition Key Transponder B1602 Generic PATS Received Invalid Format Of Key-Code From Ignition Key Transponder B1603 Generic Lamp Anti-Theft Indicator Circuit Failure B1604 Generic Lamp Anti-Theft Indicator Circuit Open B1605 Generic Lamp Anti-Theft Indicator Circuit Short To Battery B1606 Generic Lamp Anti-Theft Indicator Circuit Short To Ground B1607 Generic Illuminated Entry Input Circuit Failure B1608 Generic Illuminated Entry Input Open Circuit B1609 Generic Illuminated Entry Input Short Circuit To Battery B1610 Generic Illuminated Entry Input Short Circuit To Ground B1611 Generic Wiper Rear Mode Select Switch Circuit Failure B1612 Generic Wiper Rear Mode Select Switch Circuit Open B1613 Generic Wiper Rear Mode Select Switch Circuit Short To Battery B1614 Generic Wiper Rear Mode Select Switch Circuit Short To Ground B1615 Generic Wiper Rear Disable Switch Circuit Failure B1616 Generic Wiper Rear Disable Switch Circuit Open B1617 Generic Wiper Rear Disable Switch Circuit Short To Battery B1618 Generic Wiper Rear Disable Switch Circuit Short To Ground B1619 Generic Wiper Rear Low Limit Input Circuit Failure B1620 Generic Wiper Rear Low Limit Input Circuit Open B1621 Generic Wiper Rear Low Limit Input Circuit Short To Battery B1622 Generic Wiper Rear Low Limit Input Circuit Short To Ground B1623 Generic Lamp Keypad Output Circuit Failure B1624 Generic Lamp Keypad Output Open Circuit B1625 Generic Lamp Keypad Output Short Circuit To Battery B1626 Generic Lamp Keypad Output Short Circuit To Ground B1627 Generic PRNDL Reverse Input Circuit Failure B1628 Generic PRNDL Reverse Input Open Circuit B1629 Generic PRNDL Reverse Input Short To Battery B1630 Generic PRNDL Reverse Input Short Circuit To Ground B1631 Generic Mirror Driver Left Circuit Failure B1632 Generic Mirror Driver Left Circuit Open B1633 Generic Mirror Driver Left Circuit Short To Battery B1634 Generic Mirror Driver Left Circuit Short To Ground B1635 Generic Mirror Driver Right Circuit Failure B1636 Generic Mirror Driver Right Circuit Open B1637 Generic Mirror Driver Right Circuit Short To Battery B1638 Generic Mirror Driver Right Short To Ground B1639 Generic Mirror Passenger Left Circuit Failure B1640 Generic Mirror Passenger Left Circuit Open B1641 Generic Mirror Passenger Left Circuit Short To Battery B1642 Generic Mirror Passenger Left Circuit Short To Ground B1643 Generic Mirror Passenger Right Circuit Failure B1644 Generic Mirror Passenger Right Circuit Open B1645 Generic Mirror Passenger Right Circuit Short To Battery B1646 Generic Mirror Passenger Right Circuit Short To Ground B1647 Generic Seat Driver Recline Forward Circuit Failure B1648 Generic Seat Driver Recline Forward Circuit Open B1649 Generic Seat Driver Recline Forward Circuit Short To Battery B1650 Generic Seat Driver Recline Forward Circuit Short To Ground B1651 Generic Seat Driver Recline Backward Circuit Failure B1652 Generic Seat Driver Recline Backward Circuit Open B1652 GM Loss of Keep Alive Memory (KAM) B1653 Generic Seat Driver Recline Backward Circuit Short To Battery B1654 Generic Seat Driver Recline Backward Circuit Short To Ground B1655 Generic Seat Driver Rear Up Circuit Failure B1656 Generic Seat Driver Rear Up Circuit Open B1656 GM EEPROM Write Error B1657 Generic Seat Driver Rear Up Circuit Short To Battery B1658 Generic Seat Driver Rear Up Circuit Short To Ground B1658 GM EEPROM Checksum Error B1659 Generic Seat Driver Front Up Circuit Failure B1660 Generic Seat Driver Front Up Circuit Open B1661 Generic Seat Driver Front Up Circuit Short To Battery B1662 Generic Seat Driver Front Up Circuit Short To Ground B1663 Generic Seat Driver Front Up/Down Motor Stalled B1664 Generic Seat Driver Rear Up/Down Motor Stalled B1665 Generic Seat Driver Forward/Backward Motor Stalled B1666 Generic Seat Driver Recline Motor Stalled B1667 Generic Mirror Driver Up/Down Motor Stalled B1668 Generic Mirror Driver Right/Left Motor Stalled B1669 Generic Mirror Passenger Up/Down Motor Stalled B1670 Generic Mirror Passenger Right/Left Motor Stalled B1671 Generic Battery Module Voltage Out Of Range B1672 Generic Seat Driver Occupied Input Circuit Failure B1673 Generic Seat Driver Occupied Input Circuit Open B1674 Generic Seat Driver Occupied Input Circuit Short To Battery B1675 Generic Seat Driver Occupied Input Circuit Short To Ground B1676 Generic Battery Pack Voltage Out Of Range B1677 Generic Alarm Panic Input Circuit Failure B1678 Generic Alarm Panic Input Circuit Open B1679 Generic Alarm Panic Input Circuit Short To Battery B1680 Generic Alarm Panic Input Circuit Short To Ground B1681 Generic PATS Transceiver Module Signal Is Not Received B1682 Generic PATS Is Disabled (Check Link Between PATS And Transponder) B1683 Generic Mirror Driver/Passenger Switch Circuit Failure B1684 Generic Mirror Driver/Passenger Switch Circuit Open B1685 Generic Lamp Dome Input Circuit Failure B1686 Generic Lamp Dome Input Circuit Open B1687 Generic Lamp Dome Input Circuit Short To Battery B1688 Generic Lamp Dome Input Circuit Short To Ground B1689 Generic Autolamp Delay Circuit Failure B1690 Generic Autolamp Delay Circuit Open B1691 Generic Autolamp Delay Circuit Short To Battery B1692 Generic Autolamp Delay Circuit Short To Ground B1693 Generic Autolamp On Circuit Failure B1694 Generic Autolamp On Circuit Open B1695 Generic Autolamp On Circuit Short To Battery B1696 Generic Autolamp On Circuit Short To Ground B1697 Generic Mirror Driver/Passenger Switch Circuit Short To Battery B1697 GM Mirror Switch Input Shorted to Ground B1698 Generic Mirror Driver/Passenger Switch Circuit Short To Ground B1698 GM Mirror Switch L Up Input Stuck High B1699 Generic Passenger's Seat Occupied Switch Circuit Short to Ground B1700 Generic Passenger's Seatbelt Tension Reducer Circuit Short to Ground B1701 Generic Seat Driver Recline Forward Switch Circuit Failure B1702 Generic Seat Driver Recline Forward Switch Circuit Open B1702 GM Mirror Switch Input Shorted to Ground B1703 Generic Seat Driver Recline Forward Switch Circuit Short To Battery B1703 GM Mirror Switch L Down Input Stuck High B1704 Generic Seat Driver Recline Forward Switch Circuit Short To Ground B1705 Generic Seat Driver Recline Rearward Switch Circuit Failure B1706 Generic Seat Driver Recline Rearward Switch Circuit Open B1707 Generic Seat Driver Recline Rearward Switch Circuit Short To Battery B1707 GM Mirror Switch Input Shorted to Ground B1708 Generic Seat Driver Recline Rearward Switch Circuit Short To Ground B1708 GM Mirror Switch R Up Input Stuck High B1709 Generic Seat Driver Front Up Switch Circuit Failure B1710 Generic Seat Driver Front Up Switch Circuit Open B1711 Generic Seat Driver Front Up Switch Circuit Short To Battery B1712 Generic Seat Driver Front Up Switch Circuit Short To Ground B1712 GM Mirror Switch Input Shorted to Ground B1713 Generic Seat Driver Front Down Switch Circuit Failure B1713 GM Mirror Switch R Down Input Stuck High B1713 GM Mirror Switch R Down Input Stuck High B1714 Generic Seat Driver Front Down Switch Circuit Open B1715 Generic Seat Driver Front Down Switch Circuit Short To Battery B1716 Generic Seat Driver Front Down Switch Circuit Short To Ground B1717 Generic Seat Driver Forward Switch Circuit Failure B1717 GM Mirror Power Fold Control Switch Shorted Low B1718 Generic Seat Driver Forward Switch Circuit Open B1718 GM Power Folding Mirror Switch Input Circuit High B1719 Generic Seat Driver Forward Switch Circuit Short To Battery B1720 Generic Seat Driver Forward Switch Circuit Short To Ground B1721 Generic Seat Driver Rearward Switch Circuit Failure B1722 Generic Seat Driver Rearward Switch Circuit Open B1723 Generic Seat Driver Rearward Switch Circuit Short To Battery B1724 Generic Seat Driver Rearward Switch Circuit Short To Ground B1725 Generic Seat Driver Rear Up Switch Circuit Failure B1726 Generic Seat Driver Rear Up Switch Circuit Open B1727 Generic Seat Driver Rear Up Switch Circuit Short To Battery B1728 Generic Seat Driver Rear Up Switch Circuit Short To Ground B1729 Generic Seat Driver Rear Down Switch Circuit Failure B1730 Generic Seat Driver Rear Down Switch Circuit Open B1731 Generic Seat Driver Rear Down Switch Circuit Short To Battery B1732 Generic Seat Driver Rear Down Switch Circuit Short To Ground B1733 Generic Mirror Driver Vertical Switch Circuit Failure B1734 Generic Mirror Driver Vertical Switch Circuit Open B1735 Generic Mirror Driver Vertical Switch Circuit Short To Battery B1735 GM Driver Seat Front Up Switch CKT Malf B1736 Generic Mirror Driver Vertical Switch Circuit Short To Ground B1737 Generic Mirror Driver Horizontal Switch Circuit Failure B1738 Generic Mirror Driver Horizontal Switch Circuit Open B1739 Generic Mirror Driver Horizontal Switch Circuit Short To Battery B1740 Generic Mirror Driver Horizontal Switch Circuit Short To Ground B1740 GM Driver Seat Front Down Switch CKT Malf B1741 Generic Mirror Passenger Vertical Switch Circuit Failure B1742 Generic Mirror Passenger Vertical Switch Circuit Open B1743 Generic Mirror Passenger Vertical Switch Circuit Short To Battery B1744 Generic Mirror Passenger Vertical Switch Circuit Short To Ground B1745 Generic Mirror Passenger Horizontal Switch Circuit Failure B1745 GM Driver Seat Rear Up Switch CKT Malf B1746 Generic Mirror Passenger Horizontal Switch Circuit Open B1747 Generic Mirror Passenger Horizontal Switch Circuit Short To Battery B1748 Generic Mirror Passenger Horizontal Switch Circuit Short To Ground B1749 Generic Park/Neutral Switch Circuit Failure B1750 Generic Park/Neutral Switch Circuit Open B1750 GM Driver Seat Rear Down Switch CKT Malf B1751 Generic Park/Neutral Switch Circuit Short To Battery B1752 Generic Park/Neutral Switch Circuit Short To Ground B1753 Generic Hazard Flash Output Circuit Failure B1754 Generic Hazard Flash Output Circuit Open B1755 Generic Hazard Flash Output Circuit Short Battery B1755 GM Driver Seat Asm Forward Switch CKT Malf B1756 Generic Hazard Flash Output Circuit Short To Ground B1757 Generic Seat Driver Rear Down Circuit Failure B1758 Generic Seat Driver Rear Down Circuit Open B1759 Generic Seat Driver Rear Down Circuit Short To Battery B1760 Generic Seat Driver Rear Down Circuit Short To Ground B1760 GM Driver Seat Asm Rearward Switch CKT Malf B1760 GM CD Changer Not Responding B1761 Generic Seat Driver Front Down Circuit Failure B1762 Generic Seat Driver Front Down Circuit Open B1763 Generic Seat Driver Front Down Circuit Short To Battery B1764 Generic Seat Driver Front Down Circuit Short To Ground B1765 Generic Seat Driver Forward Circuit Failure B1766 Generic Seat Driver Forward Circuit Open B1767 Generic Seat Driver Forward Circuit Short To Battery B1768 Generic Seat Driver Forward Circuit Short To Ground B1769 Generic Seat Driver Backward Circuit Failure B1770 Generic Seat Driver Backward Circuit Open B1771 Generic Seat Driver Backward Circuit Short To Battery B1772 Generic Seat Driver Backward Circuit Short To Ground B1773 Generic Mirror Driver Up Circuit Failure B1774 Generic Mirror Driver Up Circuit Open B1775 Generic Mirror Driver Up Circuit Short To Battery B1776 Generic Mirror Driver Up Circuit Short To Ground B1777 Generic Driver's Seatbelt Tension Reducer Circuit Short to Ground B1778 Generic Mirror Driver Down Circuit Failure B1779 Generic Mirror Driver Down Circuit Open B1780 Generic Mirror Driver Down Circuit Short To Battery B1780 GM Theft Lock Enabled B1781 Generic Mirror Driver Down Short To Ground B1782 Generic Mirror Passenger Up Circuit Failure B1783 Generic Mirror Passenger Up Circuit Open B1784 Generic Mirror Passenger Up Circuit Short To Battery B1785 Generic Mirror Passenger Up Circuit Short To Ground B1786 Generic Mirror Passenger Down Circuit Failure B1787 Generic Mirror Passenger Down Circuit Open B1788 Generic Mirror Passenger Down Circuit Short To Battery B1789 Generic Mirror Passenger Down Circuit Short To Ground B1790 Generic Autolamp Sensor Input Circuit Failure B1791 Generic Autolamp Sensor Input Circuit Open B1792 Generic Autolamp Sensor Input Circuit Short To Battery B1793 Generic Autolamp Sensor Input Circuit Short To Ground B1794 Generic Lamp Headlamp Low-Beam Circuit Failure B1795 Generic Lamp Headlamp Low-Beam Circuit Open B1796 Generic Lamp Headlamp Low-Beam Circuit Short To Battery B1797 Generic Lamp Headlamp Low-Beam Circuit Short To Ground B1798 Generic Lamp Turn Signal Front Output Circuit Failure B1799 Generic Lamp Turn Signal Front Output Circuit Open B1800 Generic Lamp Turn Signal Front Output Circuit Short To Battery B1801 Generic Lamp Turn Signal Front Output Circuit Short To Ground B1802 Generic Lamp Turn Signal Rear Output Circuit Failure B1803 Generic Lamp Turn Signal Rear Output Circuit Open B1804 Generic Lamp Turn Signal Rear Output Circuit Short To Battery B1805 Generic Lamp Turn Signal Rear Output Circuit Short To Ground B1805 GM Ignition Switch Problem B1806 Generic Lamp Tail Output Circuit Failure B1807 Generic Lamp Tail Output Circuit Open B1808 Generic Lamp Tail Output Circuit Short To Battery B1809 Generic Lamp Tail Output Circuit Short To Ground B1810 Generic Lamp Backup Switch Input Circuit Failure B1811 Generic Lamp Backup Switch Input Circuit Open B1812 Generic Lamp Backup Switch Input Circuit Short To Battery B1813 Generic Lamp Backup Switch Input Circuit Short To Ground B1814 Generic Wiper Rear Motor Down Relay Coil Circuit Failure B1815 Generic Wiper Rear Motor Down Relay Coil Circuit Open B1815 GM Driver Recline Forward Switch CKT Malf B1816 Generic Wiper Rear Motor Down Relay Coil Circuit Short To Battery B1817 Generic Wiper Rear Motor Down Relay Coil Circuit Short To Ground B1818 Generic Wiper Rear Motor Up Relay Coil Circuit Failure B1819 Generic Wiper Rear Motor Up Relay Coil Circuit Open B1820 Generic Wiper Rear Motor Up Relay Coil Circuit Short To Battery B1820 GM Driver Recline Rearward Switch CKT Malf B1821 Generic Wiper Rear Motor Up Relay Coil Circuit Short To Ground B1822 Generic Wiper Rear Park Sense Input Circuit Failure B1823 Generic Wiper Rear Park Sense Input Circuit Open B1824 Generic Wiper Rear Park Sense Input Circuit Short To Battery B1825 Generic Wiper Rear Park Sense Input Circuit Short To Ground B1825 GM Driver Recline Sensor CKT Malfunction B1826 Generic Wiper Rear High Limit Input Circuit Failure B1827 Generic Wiper Rear High Limit Input Circuit Open B1828 Generic Wiper Rear High Limit Input Circuit Short To Battery B1829 Generic Wiper Rear High Limit Input Circuit Short To Ground B1830 Generic Door Unlock Disarm Switch Circuit Failure B1830 GM Driver Lumbar Forward Switch CKT Malf B1831 Generic Door Unlock Disarm Switch Circuit Open B1832 Generic Door Unlock Disarm Switch Circuit Short To Battery B1833 Generic Door Unlock Disarm Switch Circuit Short To Ground B1834 Generic Door Unlock Disarm Output Circuit Failure B1835 Generic Door Unlock Disarm Output Circuit Open B1835 GM Driver Lumbar Rearward Switch CKT Malf B1836 Generic Door Unlock Disarm Output Circuit Short To Battery B1837 Generic Door Unlock Disarm Output Circuit Short To Ground B1838 Generic Battery Saver Power Relay Circuit Failure B1839 Generic Wiper Rear Motor Circuit Failure B1840 Generic Wiper Front Power Circuit Failure B1840 GM Driver Lumbar Up Switch CKT Malf B1841 Generic Wiper Front Power Circuit Open B1842 Generic Wiper Front Power Circuit Short To Battery B1843 Generic Wiper Front Power Circuit Short To Ground B1844 Generic Phone Handset Circuit Failure B1845 Generic Ignition Tamper Circuit Failure B1845 GM Driver Lumbar Down Switch CKT Malf B1846 Generic Ignition Tamper Circuit Open B1847 Generic Ignition Tamper Circuit Short To Battery B1848 Generic Ignition Tamper Circuit Short To Ground B1849 Generic Climate Control Temperature Differential Circuit Failure B1850 Generic Climate Control Temperature Differential Circuit Open B1850 GM Driver Lumbar Horiz Sensor CKT Malf B1851 Generic Climate Control Temperature Differential Circuit Short To Battery B1852 Generic Climate Control Temperature Differential Circuit Short To Ground B1853 Generic Climate Control Air Temperature Internal Sensor Motor Circuit Failure B1854 Generic Climate Control Air Temperature Internal Sensor Motor Circuit Open B1855 Generic Climate Control Air Temperature Internal Sensor Motor Circuit Short To Battery B1856 Generic Climate Control Air Temperature Internal Sensor Motor Circuit Short To Ground B1857 Generic Climate Control On/Off Switch Circuit Failure B1858 Generic Climate Control A/C Pressure Switch Circuit Failure B1859 Generic Climate Control A/C Pressure Switch Circuit Open B1860 Generic Climate Control A/C Pressure Switch Circuit Short To Battery B1860 GM Driver Lumbar Vert Sensor CKT Malf B1861 Generic Climate Control A/C Pressure Switch Circuit Short To Ground B1862 Generic Climate Control A/C Lock Sensor Failure B1863 Generic Ground ECU Circuit Open B1864 Generic Battery Power Supply ECU Circuit Failure B1865 Generic Battery Power Supply ECU Circuit Open B1866 Generic Battery Power Supply ECU Circuit Short To Battery B1867 Generic Battery Power Supply ECU Circuit Short To Ground B1868 Generic Lamp Air Bag Warning Indicator Circuit Failure B1869 Generic Lamp Air Bag Warning Indicator Circuit Open B1870 Generic Lamp Air Bag Warning Indicator Circuit Short To Battery B1870 GM Driver Belt Tower Up Switch CKT Malf B1871 Generic Passenger Air Bag Disable Module Fault B1872 Generic Turn Signal / Hazard Power Feed Circuit Short To Battery B1873 Generic Turn Signal / Hazard Power Feed Circuit Short To Ground B1874 Generic Cellular Phone Handset Not Present B1875 Generic Turn Signal / Hazard Switch Signal Circuit Failure B1875 GM Driver Belt Tower Down Sw CKT Malf B1876 Generic Seatbelt Driver Pretensioner Circuit Failure B1877 Generic Seatbelt Driver Pretensioner Circuit Open B1878 Generic Seatbelt Driver Pretensioner Circuit Short to Battery B1879 Generic Seatbelt Driver Pretensioner Circuit Short to Ground B1880 Generic Seatbelt Passenger Pretensioner Circuit Failure B1881 Generic Seatbelt Passenger Pretensioner Circuit Open B1882 Generic Seatbelt Passenger Pretensioner Circuit Short to Battery B1883 Generic Seatbelt Passenger Pretensioner Circuit Short to Ground B1884 Generic PAD Warning Lamp Inoperative B1885 Generic Seatbelt Driver Pretensioner Circuit Resistance Low on Squib B1886 Generic Seatbelt Passenger Pretensioner Circuit Resistance Low on Squib B1887 Generic Air Bag Driver Circuit Resistance Low or Shorted Together B1888 Generic Air Bag Passenger Circuit Resistance Low or Shorted Together B1889 Generic Passenger Airbag Disable Module Sensor Obstructed B1890 Generic PAD Warning Lamp Circuit Short to Battery B1891 Generic Air Bag Tone Warning Indicator Circuit Short to Battery B1892 Generic Air Bag Tone Warning Indicator Circuit Failure B1893 Generic GPS Antenna Open Circuit B1894 Generic Wiper Rear Motor Speed Sense Circuit Failure B1895 Generic Driver's / Passenger's Door Ajar Output Circuit Failure B1896 Generic Driver's / Passenger's Door Ajar Output Circuit Short to Battery B1897 Generic Horn Switch Circuit Failure B1898 Generic Chime Input #2 Circuit Short to Ground B1899 Generic Microphone Input Signal Circuit Open B1900 Generic Driver Side Airbag Fault B1900 GM Driver Belt Tower Vert Sen CKT Malf B1901 Generic Air Bag Crash Sensor #1 Feed/Return Circuit Short To Ground B1902 Generic Air Bag Crash Sensor #1 Ground Circuit Failure B1903 Generic Air Bag Crash Sensor #1 Ground Circuit Short To Battery B1904 Generic Air Bag Crash Sensor #2 Feed/Return Circuit Failure B1905 Generic Air Bag Crash Sensor #2 Feed/Return Circuit Short To Battery B1906 Generic Air Bag Crash Sensor #2 Feed/Return Circuit Short To Ground B1907 Generic Air Bag Crash Sensor #2 Ground Circuit Failure B1908 Generic Air Bag Crash Sensor #2 Ground Circuit Short To Battery B1909 Generic Air Bag Crash Sensor #2 Ground Circuit Short To Ground B1910 Generic Air Bag Diagnostic Monitor Ground Circuit Failure B1910 GM Generator L-Terminal Open Circuit B1911 Generic Air Bag Diagnostic Monitor Ground Circuit Short To Battery B1911 GM Generator L-Terminal Problem B1912 Generic Air Bag Diagnostic Monitor Ground Circuit Short To Ground B1913 Generic Air Bag Driver/Passenger Circuit Short To Ground B1913 GM Heated Seat Switch - Mode Input Shorted to Battery B1914 Generic Air Bag Crash Sensors #1 / #2 Circuit Short To Ground B1915 Generic Air Bag Driver Circuit Failure B1916 Generic Air Bag Driver Circuit Short To Battery B1917 Generic Air Bag Memory Clear Circuit Failure B1918 Generic Air Bag Memory Clear Circuit Open B1918 GM Heated Seat Switch - Temperature Input Shorted to Battery B1919 Generic Air Bag Memory Clear Circuit Short To Battery B1920 Generic Air Bag Passenger Circuit Failure B1921 Generic Air Bag Diagnostic Monitor Ground Circuit Open B1922 Generic Air Bag Safing Sensor Output Circuit Short To Battery B1923 Generic Air Bag Memory Clear Circuit Short To Ground B1924 Generic Air Bag Internal Diagnostic Monitor Fault or System Disarm Fault B1925 Generic Air Bag Passenger Circuit Short To Battery B1926 Generic Air Bag Passenger Pressure Switch Circuit Failure B1927 Generic Passenger Side Airbag Fault B1928 Generic Air Bag Safing Sensor Output Circuit Failure B1929 Generic Air Bag Safing Sensor Output Circuit Open B1930 Generic Air Bag Safing Sensor Output Circuit Short To Ground B1931 Generic Air Bag Crash Sensor #1 Feed/Return Circuit Failure B1932 Generic Air Bag Driver Circuit Open B1933 Generic Air Bag Passenger Circuit Open B1934 Generic Air Bag Driver Inflator Circuit Resistance Low on Squib B1935 Generic Air Bag Passenger Inflator Circuit Resistance Low on Squib B1936 Generic Air Bag Driver Circuit Short To Ground B1937 Generic Air Bag Passenger Pressure Switch Circuit Open B1938 Generic Air Bag Passenger Circuit Short To Ground B1939 Generic Air Bag Passenger Pressure Switch Circuit Short To Ground B1941 Generic Air Bag Crash Sensor #1 Feed/Return Circuit Open B1942 Generic Air Bag Crash Sensor #2 Feed/Return Circuit Open B1943 Generic Air Bag Crash Sensor #1 Ground Circuit Short To Ground B1944 Generic Air Bag Crash Sensor #1 Ground Circuit Open B1945 Generic Air Bag Crash Sensor #2 Ground Circuit Open B1946 Generic Climate Control A/C Post Evaporator Sensor Circuit Failure B1947 Generic Climate Control A/C Post Evaporator Sensor Circuit Short To Ground B1948 Generic Climate Control Water Temperature Sensor Circuit Failure B1949 Generic Climate Control Water Temperature Sensor Circuit Short To Ground B1950 Generic Seat Rear Up/Down Potentiometer Feedback Circuit Failure B1951 Generic Seat Rear Up/Down Potentiometer Feedback Circuit Open B1952 Generic Seat Rear Up/Down Potentiometer Feedback Circuit Short To Battery B1953 Generic Seat Rear Up/Down Potentiometer Feedback Circuit Short To Ground B1954 Generic Seat Front Up/Down Potentiometer Feedback Circuit Failure B1955 Generic Seat Front Up/Down Potentiometer Feedback Circuit Open B1956 Generic Seat Front Up/Down Potentiometer Feedback Circuit Short To Battery B1957 Generic Seat Front Up/Down Potentiometer Feedback Circuit Short To Ground B1958 Generic Seat Recline Forward/Backward Potentiometer Feedback Circuit Failure B1959 Generic Seat Recline Forward/Backward Potentiometer Feedback Circuit Open B1960 Generic Seat Recline Forward/Backward Potentiometer Feedback Circuit Short To Battery B1961 Generic Seat Recline Forward/Backward Potentiometer Feedback Circuit Short To Ground B1962 Generic Seat Horizontal Forward/Rearward Potentiometer Feedback Circuit Failure B1963 Generic Seat Horizontal Forward/Rearward Potentiometer Feedback Circuit Open B1964 Generic Seat Horizontal Forward/Rearward Potentiometer Feedback Circuit Short To Battery B1965 Generic Seat Horizontal Forward/Rearward Potentiometer Feedback Circuit Short To Ground B1966 Generic A/C Post Heater Sensor Circuit Failure B1967 Generic A/C Post Heater Sensor Circuit Short To Ground B1968 Generic A/C Water Pump Detection Circuit Failure B1969 Generic A/C Clutch Magnetic Control Circuit Failure B1970 Generic Passenger Seatback Forward Switch Circuit Short to Ground B1970 GM Exterior Lamp Power B1971 Generic Passenger Seatback Rearward Switch Circuit Short to Ground B1971 GM Inadvertent Power B1972 Generic Passenger Rear Seat Up Switch Circuit Short to Battery B1972 GM Low Power Driver Fault B1973 Generic Passenger Rear Seat Down Switch Circuit Short to Battery B1973 GM High Power Control Fault B1974 Generic Passenger Seat Recline Forward Switch Circuit Short to Battery B1975 Generic Passenger Seat Recline Back Switch Circuit Short to Battery B1976 Generic Passenger Seat Forward Switch Circuit Short to Battery B1977 Generic Passenger Front Seat Up Switch Circuit Short to Battery B1978 Generic Passenger Front Seat Down Switch Circuit Short to Battery B1979 Generic Passenger Seat Rearward Switch Circuit Short to Battery B1980 Generic Bulb - Outage Condition Detected B1981 Generic Memory Off Switch Circuit Short to Battery B1981 GM Battery Voltage Low B1982 Generic Driver's Door Unlock Relay Circuit Failure B1982 GM Device Power Circuit High B1983 Generic Driver's Door Unlock Relay Circuit Short to Battery B1983 GM Device Power Circuit Low B1984 Generic Seat Switch Lumbar Inflate Circuit Failure B1985 Generic Seat Switch Lumbar Deflate Circuit Failure B1986 Generic Driver's Seat Seatback Autoglide Rearward Switch Circuit Failure B1987 Generic Pedal Forward / Rearward Motor Stalled B1988 Generic Pedal Position Forward Switch Circuit Short to Battery B1989 Generic Pedal Position Rearward Switch Circuit Short to Battery B1990 Generic Pedal Forward / Rearward Potentiometer Feedback Circuit Failure B1991 Generic Pedal Forward / Rearward Potentiometer Feedback Circuit Short to Battery B1992 Generic Driver Side, Side mount Airbag Circuit Short to Vbatt B1993 Generic Driver Side, Side mount Airbag Circuit Short to Ground B1994 Generic Driver Side, Side mount Airbag Circuit Open B1995 Generic Driver Side, Side mount Airbag Low resistance on Squib B1996 Generic Passenger Side, Side mount Airbag Circuit Short to Vbatt B1997 Generic Passenger Side, Side mount Airbag Circuit Short to Ground B1998 Generic Passenger Side, Side mount Airbag Circuit Open B1999 Generic Passenger Side, Side mount Airbag Low resistance on Squib B2100 Generic Door Driver Key Cylinder Switch Failure B2101 Generic Head Rest Switch Circuit Failure B2101 GM Recline Aft Switch Failed B2102 Generic Antenna Circuit Short to Ground B2102 GM Recline Forward Switch Failed B2103 Generic Antenna Not Connected B2103 GM Rear Vertical Down Switch Failed B2104 Generic Door Passenger Key Cylinder Switch Failure B2104 GM Rear Vertical Up Switch Failed B2105 Generic Throttle Position Input Out of Range Low B2105 GM Horizontal Aft Switch Failed B2106 Generic Throttle Position Input Out of Range High B2106 GM Horizontal Forward Switch Failed B2107 Generic Front Wiper Motor Relay Circuit Short to Vbatt B2107 GM Front Vertical Down Switch Failed B2108 Generic Trunk Key Cylinder Switch Failure B2108 GM Front Vertical Up Switch Failed B2109 Generic Heated Wind Shield Relay Short to Vbatt (changed from Failure 2/6/97) B2109 GM Lumbar Aft Switch Failed B2110 Generic Front Wiper Motor Relay Circuit Open (changed from Failure 2/6/97) B2110 GM Lumbar Forward Switch Failed B2111 Generic All Door Lock Input Short to Ground B2111 GM Lumbar Down Switch Failed B2112 Generic Door Driver Set Switch Stuck Failure B2112 GM Lumbar Up Switch Failed B2113 Generic Heated Windshield Input Short to Ground B2114 Generic Front Washer Input Short to Ground B2115 Generic Rear Washer Input Short to Ground B2115 GM Recline Sensor Failed B2116 Generic Door Driver Reset Switch Stuck Failure B2116 GM Rear Vertical Sensor Failed B2117 Generic Driver Side, Side mount Airbag Low capacitance on Squib B2117 GM Horizontal Sensor Failed B2118 Generic Passenger Side, Side mount Airbag Low capacitance on Squib B2118 GM Front Vertical S
Entire Thread
Body Chassis DTC Error Codes
05/13/09 06:18 PM
65
guests, and
5
spiders. |
Admin,
Global Mod,
