Most Online425 Oct 19th, 2025
#2863 - 10/21/08 01:19 PM
Re: Injectors offset voltage times not created equal
[Re: teamzr1]
tici
So you think that in case of the 98-99 F-body the injectors were so different (28.5 vs. 26.3 Lbs-Hr) that the delay had to be increased by 30%?
Notice that the camshaft was exctly the same for both years. Heads are the same too.
At the beginnig of this thread you describe the situation before and after programming the correct delay time. How did you find out this time? From the manufacturer? Try and error? If by try and error how did you find out the opitmal values? Dyno? Scanner?
Stefano
16
guests, and
7
spiders. |
Admin,
Global Mod,
