Maintaining correct tire inflation pressure helps optimize tire performance and fuel economy. Correct tire inflation pressure allows drivers to experience tire comfort, durability and performance designed to match the needs of their vehicles.
Tire deflection (the tread and sidewall flexing where the tread comes into contact with the road) will remain as originally designed and excessive sidewall flexing and tread squirm will be avoided. Heat buildup will be managed and rolling resistance will be appropriate. Proper tire inflation pressure also stabilizes the tire's structure, blending the tire's responsiveness, traction and handling.
Disadvantages of Underinflation
An underinflated tire can't maintain its shape and becomes flatter than intended while in contact with the road. If a vehicle's tires are underinflated by only 6 psi it could weaken the tire's internal structure and eventually lead to tire failure.
Lower inflation pressures will allow more deflection as the tire rolls. This will build up more internal heat, increase rolling resistance (causing a reduction in fuel economy of up to 5%) and reduce the tire's tread life by as much as 25% while increasing the probability of irregular treadwear.
Drivers would also find a noteworthy loss of steering precision and cornering stability. While 6 psi doesn't seem excessively low, it typically represents about 20% of a passenger car tire's recommended pressure.
Disadvantages of Overinflation
An overinflated tire is stiff and unyielding and the size of its footprint in contact with the road is reduced. If a vehicle's tires are overinflated by 6 psi, they could be damaged more easily when encountering potholes or debris in the road, as well as experience irregular tread wear.
Higher inflated tires cannot isolate road irregularities as well causing the vehicle to ride harsher and transmit more noise into its interior.
However, higher inflation pressures reduce rolling resistance slightly and typically provide a slight improvement in steering response and cornering stability. This is why participants who use street tires in autocrosses, track events and road races run higher than normal inflation pressures.
