Topics3,615
Posts6,713
Most Online265 Jan 21st, 2023
#3180 - 10/28/09 09:56 AM
2010 engine specs
2010 "LS9" 6.2L V-8 SC ( LS9 )
Type: 6.2L Gen IV V-8 Small Block
Displacement: 6162 cc (376 ci)
Engine Orientation Longitudinal
Compression ratio: 9.1:1
Valve configuration: Overhead valves (2 valves per cylinder)
Assembly site: Wixom, MI
Valve lifters: Hydraulic roller
Firing order: 1 - 8 - 7 - 2 - 6 - 5 - 4 - 3
Bore x stroke: 103.25 x 92mm
Fuel system: Sequential fuel injection
Fuel Type: Premium required
Maximum Engine Speed: 6600 RPM
Emissions controls: Catalytic converter
Three-way catalyst
Positive crankcase ventilation
Valves per cylinder 2
Bore Center (mm) 111.76
Applications: Horsepower: hp ( kw )
Chevrolet Corvette ZR1 638 hp ( 476 kW ) @ 6500rpm SAE CERTIFIED
Applications: Torque: lb-ft ( Nm )
Chevrolet Corvette ZR1 604 lb-ft ( 819 Nm ) @ 3800 rpm SAE CERTIFIED
MATERIALS
Block: Cast aluminum
Cylinder head: A356-T6 rotocast cast aluminum
Intake manifold: Cast aluminum
Exhaust manifold: Stainless steel
Main bearing caps: Forged steel
Crankshaft: Forged steel
Camshaft: Hollow steel
Connecting rods: Forged Titanium
Additional features: 2.3 L/rev Supercharger
Integrated dual coolant to air intercooler
Titanium inlet valve
Forged Pistons
Piston oil spray cooling
Hollow steel exhaust valve
Direct mount ignition coils
#3181 - 10/28/09 09:59 AM
Re: 2010 engine specs
[Re: teamzr1]
2010 "LS7" 7.0L V-8 ( LS7 )
Type: 7.0L Gen IV V-8 Small Block
Displacement: 7008 cc (427.6 ci)
Engine Orientation: L=Longitudinal T=Transverse L
Compression ratio: 11.0:1
Valves per cylinder: 2
Assembly site: P.B.C. Wixom, Mi.
Bore x stroke: 104.8 X 101.6
Bore Area: ( cm2 ) ( total engine bore area ) 689.75
Fuel Type: Premium Fuel required
Engine Mass ( kg/lbs ) 206 / 454
Application: Horsepower: hp ( kw )
Chevrolet Corvette Z06 505 hp ( 377kw ) @ 6300 RPM SAE CERTIFIED
Application: Torque: lb-ft. ( Nm )
Chevrolet Corvette Z06 470 lb-ft ( 637Nm ) @ 4800 RPM SAE CERTIFIED
Maximum Engine Speed: 7100 rpm
Three-way catalyst
MATERIALS
Cylinder head: Cast aluminum
Intake manifold: Composite
Exhaust manifold: Stainless Steel
Crankshaft: Forged 4140 steel
Additional features: Extended life spark plugs
Ti Intake Valve
Extended life coolant
Oil level sensor
Oil Life System
#3182 - 10/28/09 10:00 AM
[Re: teamzr1]
2010 "LS3" 6.2L V-8 ( LS3 )
Displacement: 6162cc (376.0 ci)
Compression ratio: 10.7:1
Assembly site: St. Catharines, Ontario
Fuel type: Premium fuel recommended, not required
Engine Mass ( kg/lbs ) 183/403
Applications: Horsepower: hp ( kW )
Chevrolet Camaro 426 hp ( 318 kW ) @ 5900 rpm SAE CERTIFIED
Chevrolet Corvette 430 hp ( 321 kW ) @ 5900 rpm SAE CERTIFIED
Chevrolet Corvette w/ Optional Exhaust 436 hp ( 325 kW ) @ 5900 rpm SAE CERTIFIED
Applications: Torque: lb-ft. ( Nm )
Chevrolet Camaro 420 lb-ft ( 569 Nm ) @ 4600 rpm SAE CERTIFIED
Chevrolet Corvette 424 lb-ft ( 575 Nm ) @ 4600 rpm SAE CERTIFIED
Chevrolet Corvette w/ Optional Exhaust 428 lb-ft ( 580 Nm ) @ 4600 rpm SAE CERTIFIED
Maximum Engine Speed: 6600 rpm
Three-way catalyst
Materials:
Exhaust manifold: Cast nodular iron
Main bearing caps: Powder metal
Crankshaft: Cast iron with undercut and rolled fillets
Connecting rods: Forged powder metal
Oil level sensor
Oil Life System
0 registered members (),
10
guests, and
11
spiders. |
Admin,
Global Mod,
