HTML
 2010 "LS3" 6.2L V-8 ( LS3 )
Type:	6.2L Gen IV V-8 Small Block
Displacement:	6162cc (376.0 ci)
Compression ratio: 	10.7:1
Valve configuration:	Overhead valves
Valves per cylinder:	2
Assembly site:	St. Catharines, Ontario
Valve lifters: 	Hydraulic roller
Firing order: 	1 - 8 - 7 - 2 - 6 - 5 - 4 - 3
Bore x stroke:	103.25 x 92mm
Fuel system: 	Sequential fuel injection
Fuel type:	Premium fuel recommended, not required
Engine Orientation	Longitudinal
Valves per cylinder	2
Bore Center (mm)	111.76
Engine Mass ( kg/lbs )	183/403
Applications:	Horsepower: hp ( kW )
Chevrolet Camaro	426 hp ( 318 kW ) @ 5900 rpm    SAE CERTIFIED
Chevrolet Corvette	430 hp ( 321 kW ) @ 5900 rpm    SAE CERTIFIED
Chevrolet Corvette w/ Optional Exhaust	436 hp ( 325 kW ) @ 5900 rpm    SAE CERTIFIED
Applications:	Torque: lb-ft. ( Nm )
Chevrolet Camaro	420 lb-ft ( 569 Nm ) @ 4600 rpm  SAE CERTIFIED
Chevrolet Corvette	424 lb-ft ( 575 Nm ) @ 4600 rpm  SAE CERTIFIED
Chevrolet Corvette w/ Optional Exhaust	428 lb-ft ( 580 Nm ) @ 4600 rpm  SAE CERTIFIED
Maximum Engine Speed:	6600 rpm
Emissions controls:	Catalytic converter
	Three-way catalyst
	Positive crankcase ventilation
Materials:
Block:	Cast aluminum
Cylinder head:	Cast aluminum
Intake manifold: 	Composite
Exhaust manifold:	Cast nodular iron
Main bearing caps:	Powder metal
Crankshaft:	Cast iron with undercut and rolled fillets
Camshaft:	Hollow steel
Connecting rods:	Forged powder metal
Additional features:	Extended life spark plugs
	Extended life coolant
	Oil level sensor
	Oil Life System
