HTML
 2010 Tremec TR6060 (MZ6)
Type:	Rear wheel drive, six-speed manual overdrive transmission
Engine range:	6.2L ( LS3 )
Maximum engine torque: 	430 lb-ft ( 580 Nm )
Maximum gearbox torque:	430 lb-ft ( 580 Nm )
Gear ratios:	MZ6
First:	2.966
Second:	2.066
Third:	1.426
Fourth:	1.000
Fifth:	0.710
Sixth:	0.562
Reverse:	3.276
Final Drive Ratio:	3.420
Maximum validated gross vehicle weight: 	4000 lb ( 1680 kg )
Case material: 	Aluminum
Center distance:	85mm
Fluid type:	Texaco ATF Type III 1863
Transmission weight:	Wet: 54.9 kg (121 lb )
Fluid capacity (approximate): 	Dry: 3.8L (4.0 qt) 117 oz.
Power take off:	No
Applications: 	Corvette Grand Sport Coupe and Convertible
