HTML
 2010 Tremec TR6060 (MH3)
Type:	Rear wheel drive, six-speed manual overdrive transmission
Engine range:	6.2L SC  ( LS9 )
Maximum engine torque: 	604 lb-ft ( 819 Nm )
Maximum gearbox torque:	650 lb-ft ( 881 Nm ) 1st-4th,  630 lb-ft ( 855 Nm ) 5th-6th
Gear ratios:	MH3
First:	2.289
Second:	1.611
Third:	1.208
Fourth:	1.000
Fifth:	0.818
Sixth:	0.675
Reverse:	3.106
Final Drive Ratio:	3.420
Maximum validated gross vehicle weight:	4000 lb ( 1680 kg )
Case material: 	Aluminum
Center distance:	85mm
Fluid type:	Texaco ATF Type III 1863
Transmission weight:	Wet: 54.9 kg (121 lb )
Fluid capacity (approximate): 	Dry: 3.8L (4.0 qt) 117 oz.
Power take off:	No
Applications: 	Corvette ZR1
