Engines
6.2L V-8 LS3
7.0L V-8 LS7 (Z06)
Displacement (cu in / cc):
376 / 6162
427.6 / 7008
Bore & stroke (in / mm):
4.06 x 3.62 / 103.25 x 92
4.125 x 4 / 104.8 x 101.6
Block material:
cast aluminum
Cylinder head material:
cast aluminum
Valvetrain:
overhead valve, 2 valves per cylinder
Fuel delivery:
SFI (sequential fuel injection)
Compression ratio:
10.7:1
11:1
Horsepower
(hp / kW @ rpm):
430 / 321 @ 5900* w/ std. exhaust
436 / 325 @ 5900* w/ opt. exhaust
505 / 377 @ 6300*
Torque (lb-ft / Nm @ rpm):
424 / 575 @ 4600* w/ std. exhaust
428 / 580 @ 4600* w/ opt. exhaust
470 / 637 @ 4800*
Recommended fuel:
premium recommended but not required
premium required
Estimated fuel economy :
TBD
Transmissions
6-speed manual
Base and Z06
6-speed manual, w/optional Z51 Performance Package
6-speed paddle-shift automatic
Gear ratios (:1):
First:
2.66
2.97
4.03
Second:
1.78
2.07
2.36
Third:
1.30
1.43
1.53
Fourth:
1.00
1.00
1.15
Fifth:
0.74
0.71
0.85
Sixth:
0.50
0.57
0.67
Reverse:
2.90
3.28
3.06
Final drive ratio:
3.42
3.42
2.56
Chassis / Suspension Coupe and Convertible
Z06
Front:
short/long arm ( SLA ) double wishbone, cast aluminum upper & lower control arms, transverse-mounted composite leaf spring, monotube shock absorber
Rear:
Traction control:
electronic traction control; Active Handling
Brakes
Z06
Type:
front and rear power-assisted disc with ABS; cross-drilled rotors with Z51 package and Magnetic Ride Control
front and rear power-assisted disc with ABS with 6-piston front and 4-piston rear calipers, cross-drilled rotors
Rotor diameter x thickness (in / mm): front: 12.8 x 1.26 / 325 x 32
rear: 12 x 1 / 305 x 26;
Z51 Performance Package:
front: 13.4 x 1.26 / 340 x 32
rear: 13 x 1 / 330 x 26
front: 14 x 1.3 / 355 x 32
rear: 13.4 x 1 / 340 x 26
Wheels & Tires
Wheel size:
front: 18 inch x 8.5 inch
rear: 19 inch x 10 inch
front: 18 inch x 9.5 inch
rear: 19 inch x 12 inch
Tires:
Goodyear Eagle F1 Supercar (w/Z51)
Extended Mobility
front: P245/40ZR18
rear: P285/35ZR19
Goodyear Eagle F1 Supercar Extended Mobility
front: P275/35ZR18
rear: P325/30ZR19
Dimensions
Z06
Wheelbase (in / mm):
105.7 / 2685
Overall length (in / mm):
174.6 / 4435
175.6 / 4460
Overall width (in / mm): 72.6 / 1844
75.9 / 1928
Overall height (in / mm):
49 / 1244
Curb weight (lb / kg):
Coupe: 3217 / 1459
Conv.: 3246 / 1473
3162 / 1434
Interior
Interior volume (cu ft / L):
52 / 1475 (all models)
Headr oom (in / mm): 38 / 962 (all models)
Legroom (in / mm): 43 / 1092 (all models)
Shoulder room (in / mm):
55 / 1397 (all models)
Hip room (in / mm):
54 / 1371 (all models)
Capacities
Cargo volume
(cu ft / L):
Coupe and Z06: 22 / 634
Convertible: 11 / 295 (top up); 7.5 / 212 (top down)
Fuel tank (gal / L):
18 / 68.1
Engine oil (qt / L):
Coupe and Convertible: 5.5 / 5.2
Z06: 8 / 7.5
* Horsepower and torque are SAE certified. A new voluntary power and torque certification procedure developed by the SAE Engine Test Code committee was approved March 31, 2005 . This procedure (J2723) ensures fair, accurate ratings for horsepower and torque by allowing manufacturers to certify their engines through third-party witness testing. GM was the first auto manufacturer to begin using the procedure and expects to use it for all newly rated engines in the future.
Note: Information shown is current at time of publication.
