Step |
Action |
Value(s) |
Yes |
No |
1 |
Did you perform the Powertrain On-Board Diagnostic (OBD) System Check? |
Go to Step 2 |
Go to Powertrain On Board Diagnostic (OBD) System Check |
2 |
Monitor the left fuel sender voltage using a scan tool.
Is the left fuel sender voltage less than the specified value? |
0.8V |
Go to Step 17 |
Go to Step 3 |
3 |
- Turn the ignition OFF.
- Turn the air conditioning system OFF.
Caution
Wrap a shop towel around the fuel pressure connection in order to reduce the risk of fire and personal injury. The towel will absorb any fuel leakage that occurs during the connection of the fuel pressure gage. Place the towel in an approved container when the connection of the fuel pressure gage is complete.
- Install the fuel pressure gauge to the fuel rail pressure test connection.
- Place the bleed hose of the fuel pressure gauge into an approved gasoline container.
- Turn the ignition ON.
- Bleed the air out of the fuel pressure gauge.
- Turn the ignition OFF for 10 seconds.
Important:
The fuel pump will run for approximately 2 seconds. Cycle the ignition as necessary in order to achieve the highest possible fuel pressure.
- Observe the fuel pressure with the fuel pump running.
Is the fuel pressure within the specified limits? |
380-420 kPa (55-61 psi) |
Go to Step 4 |
Go to Step 11 |
4 |
Important:
The fuel pressure may vary slightly when the fuel pump stops running. After the fuel pump stops running the fuel pressure should stabilize and remain constant.
After the fuel pump stops running, does the fuel pressure remain constant? |
Go to Step 5 |
Go to Step 10 |
5 |
Do you suspect the fuel pressure of dropping-off during acceleration, cruise, or hard cornering? |
Go to Step 6 |
Go to Symptoms |
6 |
Visually and physically inspect the following items for a restriction:
- The fuel filter/fuel pressure regulator (8)
- The fuel feed pipe (1)
Did you find a restriction? |
Go to Step 25 |
Go to Step 7 |
7 |
- Remove the left fuel sender assembly. Refer to Fuel Sender Assembly Replacement .
- Visually and physically inspect the following items:
- The fuel pump strainer for a restriction
- The fuel pump fuel feed pipe for leaks
- Verify the fuel pump is the correct fuel pump for this vehicle
Did you find a problem in any of these areas? |
Go to Step 25 |
Go to Step 21 |
8 |
- Relieve the fuel pressure. Refer to the Fuel Pressure Relief Procedure .
- Remove the fuel pipe shut-off adapter that is connected to the fuel return pipe (6).
- Reconnect the fuel return pipe (6) to the fuel sender.
- Lower the vehicle.
- Disconnect the fuel feed pipe (1) from the fuel rail.
- Install the fuel pipe shut-off adapter between the fuel feed pipe and the fuel rail.
- Open the valve on the fuel pipe shut-off adapter.
- Pressurize the fuel system using a scan tool.
- Close the valve in the fuel pipe shut-off adapter.
Does the fuel pressure remain constant? |
Go to Step 9 |
Go to Step 23 |
9 |
Important:
This step requires the aid of an assistant.
- Remove the fuel pipe shut-off adapter that is connected to the fuel feed pipe at the fuel rail.
- Raise the vehicle.
- Disconnect the fuel feed rear pipe (5) from the fuel sender.
- Install the fuel pipe shut-off adapter between the fuel feed rear pipe and the fuel sender.
- Close the valve in the fuel pipe shut-off adapter that is connected to the fuel feed rear pipe (5).
Go to Step 21 |
Go to Step 28 |
10 |
Important:
- Disconnect the fuel return pipe (6) from the fuel sender.
- Install the fuel pipe shut-off adapter between the fuel return pipe (6) and the fuel sender.
- Open the valve on the fuel pipe shut-off adapter that is connected to the fuel return pipe (6).
- Close the valve in the fuel pipe shut-off adapter that is connected to the fuel return pipe (6).
Go to Step 22 |
Go to Step 8 |
11 |
Is the fuel pressure above the specified limit? |
420 kPa (61 psi) |
Go to Step 12 |
Go to Step 14 |
12 |
Important
- Insert the fuel return pipe (6) into an approved gasoline container.
Go to Step 24 |
Go to step 13 |
13 |
Visually and physically inspect the fuel sender fuel return pipe for a restriction.
Go to Step 25 |
Go to Step 22 |
14 |
Is the fuel pressure above the specified value? |
0 kPa (0 psi) |
Go to Step 15 |
Go to Step 16 |
15 |
Notice
DO NOT allow the fuel pressure to exceed 517 kPa (75 psi). Excessive pressure may damage the fuel system.
- Slowly close the valve in the fuel pipe shut-off adapter that is connected to the fuel return pipe.
Does the fuel pressure rise above the specified value? |
420 kPa (61 psi) |
Go to Step 22 |
Go to Step 7 |
16 |
Turn ON the fuel pump using a scan tool.
Does the fuel pump run? |
Go to Step 20 |
Go to Fuel Pump Electrical Circuit Diagnosis |
17 |
- Add fuel if the left fuel tank is empty.
- Disconnect the fuel feed rear crossover pipe (3) at the right fuel sender.
- Insert the fuel feed rear crossover pipe (3) into an approved gasoline container.
- Command the fuel pump ON for the specified amount of time using a scan tool.
- Measure the volume of fuel.
Is the volume of fuel greater than the specified value? |
10 sec 300 ml (0.633 pt) |
Go to Step 18 |
Go to Step 29 |
18 |
- Reconnect the fuel feed rear crossover pipe (3) to the right fuel sender.
- Disconnect the fuel sender fuel feed pipe (7) from the left fuel sender.
- Insert the fuel sender fuel feed pipe into an approved gasoline container.
8 sec 332.6 ml (0.703 pt) |
Go to Step 3 |
Go to Step 19 |
19 |
- Reconnect the fuel sender fuel feed pipe (7) to the left fuel sender.
- Disconnect the fuel sender fuel feed pipe (4) from the right fuel sender.
- Connect a length of flexible fuel hose to the fuel sender fuel feed pipe nipple on the right fuel sender.
- Insert the open end of the fuel hose into an approved gasoline container.
Go to Step 3 |
Go to Step 26 |
20 |
- The fuel filter/fuel pressure regulator (8) for obstructions
- The fuel feed pipe (1) for a restriction
- The fuel pump strainer for obstructions
Go to Step 25 |
Go to Step 21 |
21 |
Replace the fuel tank pump module. Refer to Fuel Tank Pump Module Replacement .
Is the action complete? |
System OK |
22 |
Replace the fuel pressure regulator. Refer to Fuel Pressure Regulator Replacement .
System OK |
23 |
Locate and replace any leaking fuel injector(s). Refer to Fuel Injector Replacement .
System OK |
24 |
Locate and correct the restriction in the fuel return pipe (6).
System OK |
25 |
Repair the problem as necessary.
System OK |
26 |
Replace the right tank fuel sender. Refer to Fuel Sender Assembly Replacement .
System OK |
27 |
Locate and correct the restriction in the fuel sender fuel feed pipe (4, 7).
System OK |
28 |
Replace the fuel feed rear pipe (5) with the check valve (2). Refer to Fuel Hose/Pipes Assembly Replacement .
System OK |
29 |
Locate and correct the restriction in the following:
- The orifice located in the tee in the fuel feed rear pipe (5)
- The fuel feed rear pipe (5) from the tee to the fuel feed rear crossover pipe (3)
- The fuel feed rear crossover pipe (3) from the fuel feed rear pipe (5) to the right fuel sender
