VALVE LIFTERS & COMPONENTS
12499225 LS Series Camshaft lifter Kit
•Set of 16 lifters for LS series engines
•Same lifter used in LS2 and LS7
17803305 lifter Guide Kit
•Includes lifter guides and 4-bolts
•Makes for quick and easy cam swaps without having to remove the Intake manifold, valley plate or heads
•Works Gen III and IV applications (except with AFM)
D. 88958689
Racing Hydraulic Roller lifter Kit
As developed by GM Racing and GM Powertrain
For use in Gen III and Gen IV engines where sustained high RPM's are typical
Special reduced-mass material components allow for higher limiting speeds with aggressive camshaft designs Improved valve train dynamics and stability will improve horsepower, and high rpm 's Tested to 8000 rpm in GM Racing applications
Set of 16
