LSx CAMS
Part Number Description Duration lift (deg) Maximum lift (in) (1.7 rocker) Lobe Separation LSA) (deg)
12565308 2002-2004 LS6 CAM I: 204 E: 218 I: .550 E. .550 117.5
Cam requires valve spring PIN 12586484
1256l95O 2001 LS6 CAM I: 207 E: 217 I: .525 E: 116
12480110 ASA CAM I: 226 E: 236 1: .525 E: .525 110
Cam requires valve spring PIN "ASA" cam for on-highway use.
12480033 Hot CAM Kit I: 219 E: 228 I: .525 E: .525 112
Kit includes 16 LS6 valve springs PIN 12565117 and retainers
88958733 LS Hot Cam I: 219 E: 228 (1 7 rocker) I: 525 E: 525 112
Same cam as kit PIN 12480033
88958606 Showroom Stock Cam I: 239 E: 251 I: .570 E: .570 106.5
Showroom racing intake PIN 12565311 , hollow stem exhaust PIN
12565312, springs PIN 12586484,and after market notched pistons OR machine stock pistons
12571251 LS7 I: 211 E: 230 (1.8 rocker) I: .591 E: .591 121
Stock LS7 CAM shaft
12561721 L09: 2002-2006 LSI: I: 196 E: 201 I: 467 E. 479 116
Stock cam for 2002-2006 L09 and 2001-2004 LS1 engines
88958722 LS Stage 2 Cam I: 227 E: 239 (1.7 rocker) I: 551 E. 551 108
Max lift 1.8 rockers .583/.583
88958723 LS Stage 3 Cam I: 233 E: 276 (1.7 rocker) I: 595 E: 595 107
Max lift with 1.8 rockers .630/.630
