Topics3,714
Posts6,903
Page 2 of 2 1 2
#3226 - 11/23/09 01:26 PM Re: CYLINDER HEAD GASKETS & BOLT KITS [Re: teamzr1]
OIL PANS & ACCESSORIES
A. 12561828 Corvette Oil Pan (2002-2004 lS6}
• Used on 2002-2004 Corvettes wit LS6 V-8
B. 12558762 F-Car Oil Pan
• Used or 1998-2003 Camaro and Firebird LS1 V-8
C. 19172376 Circle Track Oil Pan
•Used on CT525, PIN 19171821
•8-quart capacity
•Includes oil filter adaptor
•Uses oil pan gasket PIN 12558760
D.24241872 Magnetic Drain Plug
•Catches and holds small pieces of metal before they can ca use damage
12558760 Oil Pan Gasket
•Requires 1 per engine
•Fits all LS series except LS7
12596691 Oil Pan Gasket
•For LS7 engines
11515758 Oil Pan Bolt
•M8 x30mm Ig
•Requires 12 per engine (use 13 with LS7 and L92 engines)
•For LS1. LS2, LS6. LS7 and L92 engines
12554990 Oil Pan Bolt
•M6 x 136mm Ig
•Requires 2 per engine
•For all LS series engines
12612289 Oil Pump
• For L92 engines
17801830 High Volume LS Oil Pump Kit
•High Volume pump assembly for LS series engines (except LS7 applications)
•Pump up seal included
12598212 Oil Pump
•2-stage pu mp for LS7 engines
•Will not work on standard LS crankshafts
•Must use crank sprocket PIN 12581278. timing dampener PIN 12581276. LS7 pickup tube PIN 12580855, LS7 01 1 pan PIN 12596689. and LS7 timing cover PIN 12598292
11519133 Oil Pump Bolt
•Requires 4 per engine
#3227 - 11/23/09 01:30 PM Re: CYLINDER HEAD GASKETS & BOLT KITS [Re: teamzr1]
STARTERS
G. 10465385 LS Series Starter
• Works with all LS series and Gen V-8 engines, including the LS1, LS2. LS6, L09, LQ4 and LS7
LSX Ignition Controller
89017844 Starter (reman)
•For L92 engines
10465547
Starter (reman)
•For F-Car applications
89017664 Starter (reman)
•For 2005 Corvette applications
•For LS2 engines
89017847 Starter (reman)
•For 2006-2007 Corvette applications
•For LS2, LS3 and LS7 engines
* All LS starters require one bolt P/N 11588456, and
• one bolt P/N 72567848
Page 2 of 2 1 2
1 registered members (teamzr1), 307 guests, and 5 spiders.
