by teamzr1. 07/13/25 11:19 AM
by teamzr1. 07/12/25 05:53 PM
C8 Cop Cruiser is the Winner
by teamzr1. 07/12/25 08:51 AM
by teamzr1. 07/10/25 02:52 PM
by teamzr1. 07/09/25 04:07 PM
by teamzr1. 07/10/25 04:24 PM
Topics3,621
Posts6,731
#324 - 02/13/06 08:35 PM Diagnostic Information for LS2, LS4 and LH6 Engines for Diagnostic Trouble Codes (DTC
Diagnostic Information for LS2, LS4 and LH6 Engines for Diagnostic Trouble Codes (DTCs) P0606, P0689, P1516, P1682 and/or P2176 That May Have Set Due to Low Battery Voltage Condition
2005 Chevrolet Corvette
This bulletin is being published to aid technicians in the diagnosis of the following DTCs:
• P0606 -- Control Module Internal Performance
• P0689 -- Engine Controls Ignition Relay Feedback Circuit Low Voltage
• P1516 -- Throttle Actuator Control (TAC) Module Actuator Position Performance
• P1682 -- Ignition 1 Switch Circuit 2
• P2176 -- Minimum Throttle Position Not Learned
The above DTCs may have set under a low battery voltage condition during or prior to vehicle cranking, then starting. If these codes are present, and a low battery condition exists or the customer indicates that the vehicle has experienced a low battery voltage condition, the technician should do the following:
With a Tech 2®, observe the engine RPM and the control module voltage in freeze frame and failure records for the DTC(s) set. If the engine RPM is zero or lower than idle speed and the control module voltage indicates less than 9 volts, this may indicate a low battery condition had occurred to cause these codes to set. The low battery condition should be diagnosed and corrected. Refer to SI for Battery Inspection/Test and/or Charging System Test.
If the battery voltage is within the normal operating range, refer to the DTC(s) set in SI for further diagnosis.
After the low voltage concern has been identified and addressed, clear the codes. Do not replace the ECM for this concern or replace and ECM with any of the following part numbers:
- 12597883
- 12596679
- 12597191
#325 - 02/17/06 08:14 PM Re: Diagnostic Information for LS2, LS4 and LH6 Engines for Diagnostic Trouble Codes (DTC
Low voltage does some very strange things to these cars.
What really threw me a curve when we were diagnosing my service AH light was there were no DTC's stored. I even had the scanner on when the light came on and it showed nothing.
It has happened on one other occasion but it was after the car had set for awhile. Once the voltage stabilized from the alternator charging, I checked it and it was around 12.2 volts. Right were it was when I had the message before.
1 registered members (teamzr1), 22 guests, and 17 spiders.
by teamzr1. 07/09/25 03:19 PM
by teamzr1. 07/08/25 10:07 AM
