If your looking to run a LS7 for racing or older carb based vettes GM now has a intake for that
25534394
LS7 4-Barrel Intake Manifold GM Racing design for use on LS7 heads As-cast design requires no porting for maximum performance Includes mounting bolts and instructions Uses LS7 carb intake gasket set P/N 19172113 Machined for 4150-style carburetors and has 3/8' NPT vacuum boss Also available with injector bosses P/N 25534413
Note: LSX Ignition Controller P/N 19171130 is required for carbureted applications
