This one is for LS1/6/2 engines
88958675
LS2 4-Barrel Intake Manifold ' Allows you to install a four-barrel carburetor on a LS series engine with cathedral ports (LS1, LS6, LS2) ' Cast aluminum open-plenum intake manifold accepts a 4150-style square-bore carburetor ' Uses LS2 carb intake gasket set P/N 19156564 ' Bosses for EFI injectors for custom applications ' Bolts and instructions supplied
Note: LSX Ignition Controller P/N 19171130 is required for carbureted applications.
