#3265 - 01/17/10 08:23 PM GM new heads
Here is several head designs GM sells
12480090
Bare C5R Racing Cylinder Head
355-T7 'as-cast' Aluminum racing head
Professional porting and machining of combustion chambers required
No seats or guides
C5R rectangle port design requires aftermarket rectangle port intake manifolds
Designed for 2.180/1.625 valves
11' valve angle
Machined for 1.625 diameter valve springs & .500 guides
Designed for big bore (4.100 min) LS7/C5R/LSX blocks
210cc 'as-cast' intake ports
70cc 'as-cast' exhaust ports, same as production LS6
30cc 'as-cast' combustion chambers
All fasteners are metric
Valve cover rails have O-ring groove for .125 O-ring
Capable of over 800 horsepower!
#3266 - 01/17/10 08:24 PM Re: GM new heads [Re: teamzr1]
LS6 Cylinder Head Assembly
Fits any 1997'2008 LS Family engine*
2.00 hollow stem intake, and 1.55 sodium filled exhaust valves
.570 max valve lift
210cc 'cathedral port' intake ports
70cc D-shaped exhaust ports
65cc combustion chambers
Bare head P/N 12564825 available separately
Heads P/N 12564824, P/N 88958665 and P/N 88958622 are
assembled with the following components:
12565311 Intake Valves
10166344 Valve Spring Retainers
12565312 Exhaust Valves
12482063 Intake Valve Stem Seals
12586484 Valve Springs
12482062 Exhaust Valve Stem Seals
10166345 Valve Locks
#3267 - 01/17/10 08:25 PM Re: GM new heads [Re: teamzr1]
For LS2
12576063
LS2 Cylinder Head Assembly
Lower cost alternative to the LS6 head
Fits any 1997'2008 LS family engine*
2.00 Solid stem intake, and 1.55 solid stem exhaust valves
.570 max valve lift
Upgrade the valves to LS6 hollow stem valves with P/N 17801930
#3268 - 01/17/10 08:26 PM Re: GM new heads [Re: teamzr1]
LS7 Cylinder Head Assembly
356-T6 aluminum head
Fully CNC'd ports and chambers
LS7 rectangle port design requires rectangle port intake manifold P/N 25534394, P/N 25534413 or P/N 12568976
Assembled with 2.20 titanium intake and 1.61 sodium filled exhaust valves
12' valve angle
Designed for big bore LS7/C5R/LSX blocks
(min 4.100 bore)
270cc CNC'd intake ports
85cc CNC'd exhaust ports
70cc CNC'd combustion chambers
Capable of over 600 horsepower
Bare head P/N 12578450 available separately
#3269 - 01/17/10 08:27 PM Re: GM new heads [Re: teamzr1]
LS7 Bare Unported Cylinder Head (not shown)
Machined for 2.20/1.61 valves
Designed for big bore LS7/C5R/LSX blocks (min 4.065 bore)
Limited availability
#3270 - 01/17/10 08:29 PM Re: GM new heads [Re: teamzr1]
CNC-Ported LS6 Cylinder Head Assembly
CNC-ported aluminum performance head
2.00 Hollow stem intake, and 1.55 sodium filled exhaust valves.570 max valve lift
250cc CNC'd 'cathedral port' intake ports
85cc CNC'd D-shaped exhaust ports
65cc CNC'd combustion chambers
88958622
CNC-Ported LS6 Racing Cylinder Head Assembly
CNC-ported aluminum racing head
.570 max valve lift
62cc CNC'd combustion chambers
#3271 - 01/17/10 08:31 PM Re: GM new heads [Re: teamzr1]
NEW CNC-Ported L92 Cylinder Head Assembly (not shown)
CNC-ported performance head
Fits any LS family engine with a bore of 4.00 or larger
Uses stock 2.165 and 1.590 valves, springs and hardware
Stock intake and exhaust port locations
.510 max lift with stock springs
280cc intake port, 100cc D-shaped exhaust port, 68cc combustion chamber
Not compatible with LS7 intake manifolds
CNC L92 Head Flow Data (4.065 bore):
Lift 0.200 0.300 0.400 0.500 0.600
Intake 150 222 260 298 332
Exhaust 105 140 168 190 201
#3272 - 01/17/10 08:31 PM Re: GM new heads [Re: teamzr1]
CNC-Ported LS2 Cylinder Head Assembly
Lower cost alternative to the CNC LS6 head
2.00 solid stem intake, and 1.55 solid stem exhaust valves
.570 max valve lift
0 registered members (), 8 guests, and 9 spiders.
