#3409 - 05/11/1008:16 PMRe: Installing a EVS 1590 Supercharger on C6
[Re: teamzr1]
Joined: Dec 2000 Posts: 6,036teamzr1 Owner - Pays the bills
Here is a BEFORE testrun results. Run was 44,000 feet duration of 15 minutes
Has a crappy Breathless tune. As seen even with E10 gas which would lean up AFR about 8% it still is running up to 14% too rich. Also seen is misfires and max flywheel torque at about 375 ft/lbs at 400 HP.
Has a Breathless CAI, weather was 50 degrees, airbridge to intake ran a average of 58 deg to a maximum of 88 deg.
Maximum WOT timing of 24 degrees. Maximum airflow was 41 lbs.
