#3434 - 06/02/1006:12 PMRe: Installing a EVS 1590 Supercharger on C6
[Re: teamzr1]
Update as of this date
Owner contacted me to say the vendor super screwed up and the SCTuner black box they programmed it to flash the A6's TCM with a 4 speed trannie flash !
There is not even a C5 with a A4 that would have had a internal TCM nor any 2008 having a 4 speed.
Owner says it took them 15 TCM flashes to get it right and at this point the dealer had to tear the A6 apart and change parts due to the wrong TCM flash being used.
Even then I do not buy the vendors answer as seen below when the TCM flash before using the SCTuner and then after the tuning tool sees both as a 2008 C6, the code segments are then same and even sees in both as a A6
This says the vendors involved never did the QA testing to assure when their tuner box flashed that valid software was being forced into the TCM and worst is no tuner tool could fix the problem since the tools saw the TCM flash as invalid
Car should be functional by next week and then final tests and tune would be done
