Dear General Motors Customer:
This notice is sent to you in accordance with the National Traffic and Motor Vehicle Safety Act.
General Motors has decided that a defect, which relates to motor vehicle safety, exists in certain 2015 model year Chevrolet Corvette vehicles.
As a result, GM is conducting a safety recall.
We apologize for this inconvenience. However, we are concerned about your safety and continued satisfaction with our products.
IMPORTANT
Your vehicle is involved in GM recall 14857.
Schedule an appointment with your GM dealer.
This service will be performed for you at no charge.
Why is your vehicle being recalled?
The toe link outer ball joint may not have been properly fastened to the knuckle in the right rear suspension during the assembly process.
A loose toe link can cause the rear suspension to make loud metallic noises, particularly when the vehicle is travelling around corners or over bumps or potholes.
Over time, if this condition is not addressed, the toe link could separate.
If separation of the toe link occurs while the vehicle is being driven, it would create sudden vehicle instability, increasing the risk of a crash.
What will we do?
Your GM dealer will inspect the knuckle for damage and replace any damaged parts as necessary.
If no damage is noted, your dealer will reassemble the toe link with a new nut and fasten it to the proper torque specification.
Because of service scheduling requirements, it is likely that your dealer will need your vehicle longer than the actual inspection time of 25 minutes.
If part replacement is required, an additional 2 hours and 15 minutes will be required.
What should you do?
You should contact your GM dealer to arrange a service appointment as soon as possible.
