Subject: Removal and Installation of the Inside Rear View Mirror RPO DD8 - keywords button connection glass glue inside ISRVM loose mirror mount rear secure view #PIC4134A - (07/20/2006)
Models: 2005-2007 Chevrolet Corvette
Condition/Concern:
When servicing the Inside Rear View Mirror (ISRVM) assembly RPO DD8, it may be noted that the mirror will not release from the windshield with the instructions in eSI.
Recommendation/Instructions:
To remove the ISRVM RPO DD8, it will be necessary to rotate the mirror clockwise to remove. Use the bottom of the mirror base as a reference and call it the 6 o'clock position. Rotate the mirror base clockwise to approximately the 9 o'clock position. The mirror will then release from the windshield. When installing the ISRVM, install with the mirror base at approximately the 9 o'clock position. Apply pressure to the mirror base against the windshield and the rotate counter clockwise to the 6 o'clock position. Reinspect the mirror and confirm it has been secured to the windshield. A slight wobble of the mirror base from left to right is considered normal.
