Subject: Air Bag Indicator On - keywords B0033 B0040 B0023 B0016 B0022 B0042 B0012 B0013 B0019 B0020 connector lamp light restraints roof SDM SIR wire #PIT4011A - (07/28/2006)
Models: 2006-2007 Chevrolet Corvette,
Condition/Concern:
You may experience a intermittent or current SIR indicator on the Instrument Panel Cluster (IPC) with DTC B0012 0E, B0013 0E, B0016 0E, B0019 0E, B0020 0E, B0022, B0023 0E, B0033 0E, B0040 0E, OR B0042 set in the Sensing and Diagnostic Module (SDM).
Recommendation/Instructions:
Inspect for a loose, missing, or broken Connector Position Assurance (CPA) retainer. If the CPA is broken, missing, or will not seat in connector correctly, replace the CPA retainer with part number: 54590003 (Orange CPA) that is located in the connector tray of the terminal repair kit.
Note: If the CPA retainer part number: 54590003 (Orange CPA) can't be located in terminal repair kit, contact Kent Moore Tools @ 1-800-GM-Tools to obtain a new package of 5.
