#373 - 10/07/05 01:45 PM Forced Induction on a C6
JR, given what we've read on different forums & from what you've told us about the LS2 engine, does adding a supercharger to a C6 make much sense since the engine can't be tuned?
#374 - 10/07/05 03:11 PM Re: Forced Induction on a C6
Without tuning there is no way I would put one on a stock C6 for air and fuel needs will greatly change as well as ping issue.
#375 - 11/05/05 07:47 PM Re: Forced Induction on a C6
Now that you have had a chance to look at the tuning software. Do you think a magnacharger on the stock bottem end is safe?
#376 - 11/05/05 08:27 PM Re: Forced Induction on a C6
The only tuning software for a C6 is LS2edit and its only for the 2005 and will not work on a 2006. It also looks like it does not support the TCM controller for the auto trannie so I would not be sure that all could be done in tuning when adding a SC'er
Better chances if the car is a '05 and using manual trannie.
In any case, the bottom end still is a weak link and I just saw another car with a maggie SC'er blow a head gasket and took out 2 pistons so anytime you add boost to a stock Corvette engine the chances are high that engine damage will occur long term though chances are better if just adding the SC'er, larger injectors, and very custom tune and NOT adding other mods such as radical cams.
Keep in mind the LS2 has even higher engine compression then what the LS1 has so the higher compression is the better chances of internal engine damage so if really wanting to be safe with a stock bottom end is to reduce the compression
