GM has released an updated Original Equipment Batteries Part Number chart for use when testing batteries using the EL-50313 GR8 Battery Tester/Charger. The chart includes cold cranking amperage (CCA) ratings and identifies the type of battery. Refer to Bulletin #15-06-03-002L for more information.
Correct battery CCA ratings and battery type are critical for proper test results when using the EL-50313. Access to the battery specification label, which contains the OEM part number and CCA rating and type, may be difficult without removing the battery. Use the updated chart for the ratings and part numbers needed to set up a proper battery test.
Electronic Parts Catalog Part Numbers
If a battery needs to be replaced, the correct ACDelco battery warranty replacement in the Electronic Parts Catalog is designated by the “Original Equipment Replacement” note in the description field. Bulletin #15-06-03-002L has additional details about how to provide feedback on battery part numbers.
Battery Testing
When testing batteries:
Select “Out of Vehicle” when setting up the test. Disconnect both of the battery cables from the battery. The battery does not need to be removed from the vehicle. Connect the EL-50313 directly to the battery terminal posts. Select the correct SAE CCA. The battery should be close to room temperature and not frozen. Select the proper battery type; Flooded, AGM, or Stop/Start AGM (AUX12 Battery).
The proper battery type must be selected to prevent battery damage and ensure correct test results.
When an automotive 12V battery is cold (below freezing), its capacity starts to be reduced. The capacity can be observed in the voltage level of the battery, as well as measured cold cranking amps. A cold battery is also resistant to charging. The colder the battery, the more these characteristics are affected. Depending how cold a battery is, it can fail testing using any type of battery test equipment, including the EL-50313 (GR8). A cold battery should be warmed to a temperature above 4°C (40°F) prior to testing.
