Firstly my apologies for the delay with a reply, a ‘medical issue’ put me on my back in hospital for a while, but it will take a lot more than that to keep me away from my vet !
I’m extremely grateful for the reply and the offer to help provide any advice about what’s happening with my girl (even my neighbours are complaining…. they say they miss the sound of that V8 roar in the morning when she starts!). Below is a status of how things developed and where I am with things right now.
Last year whenever I ran over a large pot whole or speed bump it triggered either a “Low fuel” DIC warning with the gauge dropped to zero, or a “Traction control” warning and the orange dash light illuminated. The codes were easily cleared and all quickly seemed well again. Towards the end of the year I had a couple of instanced when after stopping (after a faultless run) for coffee, fuel or shopping etc. when I got back in, she reluctantly started, with “ Reduced power “. After running through the codes and clearing everything it was back to full power and I could make it home. This became more regular to the point where every journey was a major issue and things couldn’t continue like that. So with Low fuel, traction control, service vehicle soon, and reduced power warnings I read all I could about potential vet problems. I’ve read a lot about the cars earthling issues, so I got stuck in and have removed /cleaned/ re greased G101, G102, and G401, G201 earth connectors / blocks so far. Testing after I finished each one – with no benefits, until after the last one (G201) when she started! I let it run for a few mins and all seemed ok. I turned off and went to make that celebratory cup of coffee, however on returning to restart her, I got the same issues as before. (turns over but won’t fire), with the same DIC warnings. That got me thinking - why start one time and not the next,…all I did was spin the ignition key – could the ignitions electrical switch be part of the issue?? So not sure if I should delve into that one next? Or if it’s clouding over other bigger issues. Unfortunately it will soon be “summer” over here and I fear I’m going to miss it (I think it’s on June the 27th this year !) I’m keen to get her up and running, so ANY feedback would be very gratefully received.
Codes
DIC
‘Service Vehicle Soon’ ‘Low Fuel’ ‘Service ABS’ ‘Service Traction System’ ‘Reduced Engine Power’
10 PCM
P1518 H C PCM to TAC Module Serial Data Circuit
28 TCS
C1226 H LF Excessive Wheel Speed Variation
C1225 H RF Excessive Wheel Speed Variation
C1276 H Delivered Torque Signal CKT Malfunction
U1255 H C Generic Loss Communications
38 RTD No Comms
40 BCM
B0432 H C Rear Defogger Relay Circuit
99 HVAC
B0332 h Outside Air Temp Sensor Short to GND
B0337 h Inside Air Temp Sensor Short to GND
Bo361 h Left Actuator Feedback Short to GND
B0365h Right Actuator Feedback Short to GND
A0 – LDCM
B2282 h Battery #1 Fault
B2284h Battery #2 Fault
B2264h
U1096h Loss of Communications with IPC
A1-RDCM
B2283h Battery #1 Fault
B2285h Battery #2 Fault
U1096 h Loss of Communications with IPC
A6-SCM
B0851h Battery 1 Out of Range
B0-RFA
U1096h Loss of Communication with IPC
U1016h Loss of Communication with PCM
C2120h TPM System Malfunction (No Sensors Received)
Grateful for any assistance or advice.
Regards
Stuart
