Topics3,614
Posts6,712
#415 - 10/09/05 12:45 PM Shocks
Shock absorbers have been in use since the early days of the automobile. It would stand to reason that something that has been around for so long is pretty well understood by the general driving public, right? Actually, this is far from the truth, as even automotive enthusiasts will neglect and often ignore the shock absorbers on their car, while degrading its handling performance and ride comfort.
Even worse, worn shocks can be dangerous, especially during the severe maneuvers that might be necessary to avoid an accident. As we will see, for such a simple yet effective device, shock absorbers seem to get little respect.
The Gravity of the Situation
Strangely enough, despite their name, shock absorbers don't absorb shocks. In reality, that is the job of the springs in a vehicle's suspension system. As a wheel encounters a bump, the wheel moves upward, compressing and storing the energy of the bump into the spring. This compression is actually what absorbs the shock of the bump.
But now that the spring is compressed, it contains potential energy that must be released. The spring does this by bouncing back to its original uncompressed length, at the same time pushing the vehicle's body upward. In an example of the old adage "what goes up, must come down," gravity pulls the weight of the body back down, recompressing the spring. If the shock absorbers are worn, the vehicle ends up bouncing its way down the road after every bump until all of the energy is used up. In the worst cases, this bouncing can actually pull a vehicle's tires off the ground, making the vehicle uncontrollable.
Bring on the Dampers
Shock absorbers, more properly called dampers, are mounted alongside (or inside) the springs at each corner of the vehicle. A shock absorber's job is to provide resistance to the movement of the spring. Technically speaking, it does this by taking some of the energy that is being used to compress the spring and turning it into heat. So whether the vehicle is bouncing up or down from a bump in the road, that motion is held in check by the shock absorber, and once again some of the kinetic energy released by the spring is changed into heat by the shock absorber. This conversion of energy keeps the vehicle's body from bouncing more than once or twice, providing a controlled ride and helping to keep the vehicle's tires safely in contact with the ground.
But How?
If you have ever waved your hand back and forth through water, then, in principle, you know how a shock absorber works. The resistance to motion you feel with your hand changes with speed – the faster you move your hand, the more energy it takes to push against the resistance of the water.
A shock absorber works much the same way. Inside the shock absorber there's a piston that moves inside a tube which is filled with oil. As the piston moves, the oil is forced through tiny holes and valves within the piston, precisely controlling the amount of resistance to movement. This resistance to the motion converts the energy into heat. (Yes, a shock absorber that has been doing its job over a rough road does get warm!)
What Types?
Although there have been many different designs for shock absorbers over the course of automotive history, today there are four basic types available:
Twin-tube
Mono-tube
Gas-filled mono-tube
External reservoir
Sometimes these types of shock absorbers are incorporated into a strut-type suspension that uses the shock absorber as part of the spring support, but the basic principles still apply.
The twin-tube design is the most common and often times the least expensive. These are the ordinary shock absorbers that typical passenger cars and trucks use, and they are widely available at car dealerships, auto parts stores and repair facilities. As the name implies, in a twin-tube shock, there are two actual tubes – one the outer shock body and the other a cylinder inside in which the piston moves. Tiny holes or orifices in the piston as well as special valves between the inner and outer tubes restrict the flow of oil to control wheel motion.
The limitations of twin-tube shocks become apparent when they are used over very bumpy roads. In this case, the rapid motion of the piston can cause the oil to overheat and to foam, reducing the shock absorber's ability to control wheel motion. The result is a ride that becomes increasingly sloppy, especially when traveling over a washboard surface. Heavy-duty twin-tube shock absorbers are usually stronger, with more robust piston shafts and mounting points, and they may use oils that are more resistant to foaming, but ultimately they still have the same limitations.
Mono-Tube and Gas-Filled Shocks
The heat generated in the twin-tube shock tends to get trapped within the walls of the shock absorber body, reducing its effectiveness in controlling wheel motions. The mono-tube shock absorber uses a piston traveling within a single tube that is exposed more directly to the air. The general advantages and disadvantages of this design are:
By getting rid of heat more easily, mono-tube shocks are less susceptible to overheating on rough roads.
They are more expensive to manufacture however, and the tolerances must be higher and the seals better to keep the oil inside the shock body.
To prevent foaming and bubbles in the oil, which degrades shock-absorber performance, a gas-filled mono-tube shock has a chamber of high-pressure nitrogen above the oil chamber. This high-pressure gas makes it difficult for bubbles to form in the oil, even when the shock absorber moves in and out very quickly, as it might while traveling rapidly on a very rough or washboard road.
Gas-filled shocks are expensive, since they require strict manufacturing tolerances, but they are very resistant to fade and consequently are popular in off-road racing and rallying. Gas-filled shocks, by the way, are not the same as "air shocks" which use an air chamber separate from the shock oil. An air shock is actually an air spring that raises or lowers the vehicle when air is added or removed through a valve.
External Reservoir
The top of the line in shock absorbers is the external-reservoir design. These shocks, primarily designed for ultra-high performance and racing applications, use a small, lightweight shock body that is connected through a hose to a reservoir of oil mounted in a different part of the vehicle. The goal of an external reservoir shock is to:
Reduce the weight at the wheel for better handling.
Provide better cooling for the oil in the reservoir.
Provide significant air space within the reservoir so that the hot oil can expand without blowing out seals.
Allow superb adjustability as the oil flows to and from the shock body.
External reservoir shocks are very expensive and are really only needed in extreme high-performance applications.
When to Buy Shocks
Shock absorbers last a long time, but they tend to degrade slowly throughout their life. So when is it time to replace them?
In some cases, a seal will rupture. A shock covered in oil is a good indication that it has failed.
The age-old test of bouncing on a fender is really only a rough guide as to whether your vehicle needs new shocks.
Usually the slow degradation in your shock absorber's performance won't be noticed until it affects handling fairly dramatically.
Depending on how rough your roads are, modern shocks can last 80-100,000 miles, but remember that a shock with 60,000 miles on it won't perform as well as a new one.
Shocks can be tested on a shock machine, but to do so requires them to be taken off the car. With labor rates what they are, if your mechanic already has the old shocks off, it makes sense to put new ones back on.
Replacing worn-out shocks can revitalize the handling of a vehicle, returning much of the crispness it had when new. When combined with a new set of tires, a high-mileage vehicle with sloppy handling and a bouncy ride can be transformed.
Which Ones Are Right for Me?
Choosing which shocks to buy largely depends upon what kind of vehicle you own and the kind of driving you do.
Shocks are available in a range of prices. Often you get what you pay for.
If you liked the way your vehicle rode and handled when it was new, go with original-equipment replacements.
If you are looking for more, there are a variety of options open to you, including heavy-duty shocks for carrying heavy loads and performance shocks for crisper handling.
As with most automotive components, it is important that you buy the right shocks for your specific vehicle, since mismatched shocks can drastically affect handling and could even be dangerous. The best advice will probably come from a mechanic who is familiar with your type of car. It goes without saying that if you make the right choice, the improvements in your vehicle's ride and handling can be shocking!
#416 - 10/10/05 11:00 AM Re: Shocks
Gordon Offline
Pro
Gordon  Offline
Pro
Plymouth, MI 48170
The 04 Z06 shock is often mentioned as excellent for stock ride hight C5's. However the C6 Z06 shock is now available it is the same lengeth as the C5 shock. Do you have any info which would be better for autocrossing/HSDE events/time trials.
2000 Nassua Blue FRC
08-468
#417 - 10/10/05 11:12 AM Re: Shocks
Being those shocks are just now used on low volume Z06's there is no proven results of them so I do not have that answer.
For me I say IF the car is used on street and experiencing higher speed cornering then as I did bite the bullet and spend the money on multi adjustable shocks that also can be rebuilt or revalved as to your liking so I use Penske shocks that also are nitrogen cooled.
Also a big mistake is people lowering the car but still using a shock that is designed for a longer travel on rod.
Mine were designed shorter, they are installed upsidedown so less unsprung weight and have bump stops so shocks do not bottom out.
0 registered members (), 5 guests, and 7 spiders.
