The FIA Endurance Committee has issued a 2nd Pre 6 Hours of Shanghai BoP change, handing Corvette Racing a weight break for its guest-entered GTE Pro class C7.R.
The revised BOP table sees the C7.R’s minimum car weight reduced to a near identical value to its Le Mans 24 Hours weight back from the GTE Pro BoP levels back in June.
Initially, the C7.R was due to be the second-heaviest GTE car in the class in China, with a 27kg increase from Le Mans to 1276kg.
Instead, with the change, the car’s minimum weight is 1248kg, one kilogram lighter than its Le Mans weight.
