• The standard 2020 C8 Stingray coupe has a front clearance of 5.3” and the front lift feature provides 40mm to that height.
• The NPP exhaust works much like today’s system but incorporates an internal X pipe layout for mixing to reduce non-harmonic content and create a Corvette-heritage sound.
• We recommend owners not to use any fuel labeled E85 or FlexFuel.
We also advise against use of gasoline with ethanol levels greater than 15% by volume.
Premium unleaded gasoline meeting ASTM specification D4814 with a posted octane rating of 93 is highly recommended for best performance and fuel economy of the vehicle.
Unleaded gasoline with an octane rated as low as 87 can be used, but using unleaded gasoline rated below 93 octane,
however, will lead to reduced acceleration and fuel economy.
The 1LT is 8Kg(17.6lbs) lighter than the 2LT.
The 2LT is 1Kg(2.2lbs) lighter than 3LT.
The wheels are a little heavier than the C7 rims, but also stronger
