Instrument Panel Fuse Block
The instrument panel fuse block is behind the glove box. The glove box can be accessed by unlatching the door damper and squeezing the pivot to release the damper ring. Pull the glove box bin side walls in to release the door stops. Then turn the door until the hinge hooks release from hinge pin.
To Access:
1. Open the top cover. 2. Remove the top cover by pushing inward on the latch. 3. Pull the cover upward.
To Install:
1. Insert the tabs on the back of the cover into the slots in the instrument panel. 2. Align the clip with the slots in the instrument panel. 3. Press the cover into place.
Fuses Usage 1 – 2 Front wiper 3 Cooling fan 1 4 – 5 Cooling fan 2 6 Front blower 7 Front lift/Automatic level control 8 Shifter interface board module 9 – 10 Display IP cluster/HVAC/Center stack Module 11 USB 12 – 13 – 14 Glove box 15 – 16 – 17 Remote function actuator 18 Front trunk release 19 Intelligent battery sensor 20 Exterior lighting module 1 21 Exterior lighting module 3 22 Exterior lighting module 4 23 Body control module 2 24 Exterior lighting module 6 25 Amplifier 26 Automatic occupant sensing/Electric park brake 27 Video processing module 28 Right headlamp 29 – 30 Sensing and diagnostic module/Automatic occupant sensing 31 Body control module 1 32 Column lock module 33 Data link connection/Wireless charging module 34 Telematics/Head up display 35 Horn 36 – 37 – 38 Front wash pump 39 Rear auxiliary power outlet 40 Performance data recorder/Center stack module 41 – 42 Theft deterrent 43 Left headlamp 44 Exterior lighting module 2 45 Power steering column module 46 Body control module 3 47 Exterior lighting module 5 48 Exterior lighting module 7 49 Body control module 4 50 Front auxiliary power outlet 51 – 52 Steering wheel control switch 53 Heated steering wheel 54 –
