Here I compiled summaries of those shown to be for or included for the 2020 C8 Corvette Stingray
You can either do search on the TSB number, or maybe go to dealer and see if they will let you print some of these out
or try a NHTSA website and do a search on their number included below
TSB Number: 15NA010
NHTSA Number: 10171875
TSB Date: January 23, 2020
Date Added to File: March 2, 2020
Failing Component: Engine And Engine Cooling:Exhaust System:Emission Control
Summary:
This informational bulletin provides information to dealership personnel for new vehicles with less than 1,000 miles that may not pass California smog inspection or smog inspection in other states.
TSB Number: 16NA383
NHTSA Number: 10171878
TSB Date: January 2, 2020
Failing Component: Equipment Adaptive
Summary:
This informational bulletin advises of a new fuel injection cleaner kit used for de-carbonizing the intake valves to correct conditions of rough idle, crank no start, extended crank or misfire, MIL with DTCs, and explains how top tier fuels
TSB Number: PIP5703
NHTSA Number: 10172337
TSB Date: February 28, 2020
Date Added to File: March 9, 2020
Failing Component: Electrical System
Summary:
This preliminary information communicates that the transmission control module is on restriction to help engineering root cause any early issue.
TSB Number: PIP4670H
NHTSA Number: 10165904
TSB Date: September 25, 2019
Date Added to File: October 15, 2019
Summary:
This preliminary information communication provides information to the technician about a no start or another concern after swapping an engine control module or other modules from one vehicle to another. The global architecture electrical s
TSB Number: PI0592E
NHTSA Number: 10165127
TSB Date: August 23, 2019
Date Added to File: September 23, 2019
Summary:
This preliminary information bulletin provides information om service programming system (sps) error codes e4398, e4399, e4403, m4404, m4413, e4414, e4423, e4491 or e6961).
TSB Number: 050307009I
NHTSA Number: 10172293
TSB Date: January 27, 2020
Summary:
This informational bulletin provides retail, wholesale and fleet personnel with general motors recommendations for customer concerns related to wheel alignment.
TSB Number: 16NA383
Summary:
This informational bulletin advises of a new fuel injection cleaner kit used for decarbonizing the intake valves to correct conditions of rough idle, crank no start, extended crank or misfire, MIL with DTCs, and explains how top tier fuels
TSB Number: 080310006G
NHTSA Number: 10169356
TSB Date: November 12, 2019
Date Added to File: December 16, 2019
Failing Component: Service Brakes, Hydraulic
Summary:
This technical bulletin provides a procedure on how to clean and resurface aluminum wheel bead seats for vehicles that have the condition of tire slowly goes flat, tire air loss, low tire pressure warning light illuminated, aluminum wheel bearing
TSB Number: 100089006G
NHTSA Number: 10168207
TSB Date: October 16, 2019
Date Added to File: November 25, 2019
Failing Component: Equipment:Other:Owners/Service/Other Manual
Summary:
This informational bulletin provides information for dealers how to submit a product information report (pir) (Canada only).
TSB Number: PIP5709
NHTSA Number: 10172340
Failing Component: Power Train
Summary:
This preliminary information communicates the transmission used in the 2020 corvette is on exchange with the supplier for early root cause analysis.
TSB Number: PIP5703
Summary:
TSB Number: 16NA338
NHTSA Number: 10168175
TSB Date: October 14, 2019
Summary:
This bulletin provides guidelines for dealers not required and for dealers required to contact the pqc for engine or transmission assembly replacement and explains the pqc process, gwm transaction submission, vehicle service record retention
TSB Number: 990420002K
NHTSA Number: 10168212
TSB Date: October 29, 2019
Summary:
This informational bulletin provides information on driveline clunk noise and what is acceptable and what is considered normal operations.
TSB Number: 16NA361
NHTSA Number: 10168176
TSB Date: October 8, 2019
Summary:
This informational bulletin explains possible normal condition of a flare from 1st to 2nd, even if the trans had been repaired for the flare and its still noticed.
TSB Number: 16NA109
NHTSA Number: 10165079
TSB Date: August 5, 2019
Failing Component: Steering
Summary:
This technical bulletin provides a procedure inspecting for excess grease or sealant on the exterior of the steering gear due to seeing grease or sealant on certain locations on the gear.
Failing Component: Wheels
Summary:
TSB Number: PIP5130K
NHTSA Number: 10171265
TSB Date: January 10, 2020
Date Added to File: February 10, 2020
Summary:
This preliminary information communication provides information to the technician how to diagnose and repair a vehicle with an engine that runs with an intermittent crank no start with a diagnostic trouble code P0011 or P00C6 current or his
TSB Number: 010601011K
NHTSA Number: 10168205
TSB Date: October 9, 2019
Summary:
This informational bulletin provides guidelines and diagnostic/repair information to technicians regarding vehicle engine oil consumption.
TSB Number: PIP5606E
NHTSA Number: 10165902
TSB Date: September 24, 2019
Summary:
This preliminary information communicates a vehicle may have a tick noise from the engine cold, initial start in the morning.A lifter may not have sufficient amount of oil during cold start operation (not pumped up)
TSB Number: 000601026M
NHTSA Number: 10165121
TSB Date: August 15, 2019
Summary:
This informational bulletin provides information on replacing the intake manifold when the engine is replaced after severe internal engine damage.
TSB Number: 090604026R
NHTSA Number: 10165124
TSB Date: August 21, 2019
Summary:
This bulletin provides information on identifying non-GM engine calibrations for gasoline engines using the tech 2 or gds 2.
TSB Number: 070601016F
NHTSA Number: 10165122
TSB Date: August 13, 2019
Summary:
This informational bulletin provides information on internal engine noise or damage after oil filter replacement.
