Check out the 2019 Chevrolet Corvette (C7) ZR1 perform a Top Speed Test of 214 MPH On 2.7 Mile Runway
2019 ZR1 pasted 200 MPH in thirty seconds, then reached 211 MPH about ten seconds later, eventually making it to 212 MPH at about 47 seconds & finally to 213.649 mph) another 7 seconds later for a new speed record.
Vehicle Specifications: Make: Chevrolet Model: Corvette ZR1 Year Tested: 2019 Max Power: 755 HP Max Torque: 715 lb.ft Engine: 6.2 L V8 Supercharged Gearbox: 8 Speed Automatic Drive: RWD Weight: 3,669 lbs. Distance Tested: 2.7 Miles
Runway Specifications: Length: (3.22 Miles) or (5.15 Kilometers) Width: (300 Feet) or (91.44 Meters) Elevation Above Sea Level: (8.3 Feet) or (2.53 Meters) Elevation Change: (0.25 Inches) or (0.635 Centimeters) Surface Material: Concrete - (15,000 Feet) or (4,572 Meters) Asphalt - (2,000 Feet) or (609.6 Meters)
Weather Conditions: 10:00AM EST. Temp: 72 F / 22.2 C Dew Point: 54 F / 12.22 C Wind: 15 MPH (13 KT) Direction: ESE Vehicle Heading: South to North Pressure: 30.30 in. Density Altitude: 642 ft. Surface Temp: 70 F / 21.11 C
2:00PM EST. Temp: 77 F / 25 C Dew Point: 54 F / 12.22 C Wind: 13 MPH (11 KT) Direction: SSE Vehicle Heading: South to North Pressure: 30.21 in. Density Altitude: 1042 ft. Surface Temp: 88 F / 31.11 C
