If there is a driving problem with C8 need to assure DCT is not in park mode as would not be able to get C8 moved to a towing trailer
The following procedure allows the vehicle to remain in Neutral:
Engine Off Driver in Vehicle
1. Ignition ON Engine Running.
2. Apply the brake pedal.
3. Shift to Neutral.
4. Release Parking Brake.
5. Turn off the engine and release the brake pedal.
6. The indicator should continue to show N. If it does not, repeat steps 24.
7. Vehicle is now in Neutral Service Mode.
Engine Off Driver out of Vehicle
3. Open the door.
4. Shift to Neutral.
5. Release Parking Brake.
6. Turn off the engine and release the brake pedal.
7. The indicator should continue to show N. If it does not, repeat steps 25.
8. Exit the vehicle and close the door. Vehicle is now in Neutral Service Mode.
Note: The vehicle may automatically shift to Park upon re-entry.
Engine On Driver in Vehicle
5. Release the brake pedal.
6. Vehicle is now in Neutral Service Mode.
Engine On Driver out of Vehicle
3. Open the door.
6. Release the brake pedal.
7. The indicator should continue to show N. If it does not, repeat steps 24.
9. Vehicle is now in Neutral Service Mode.
