2007 Tremec T56 (MM6) 5/25/2006
Type: rear wheel drive, six-speed manual overdrive transmission
Engine range: 6.0L - 7.0L gas
Maximum engine torque: 470 lb-ft ( 637 Nm )
Gear ratios: MM6
First: 2.66
Second: 1.78
Third: 1.3
Fourth: 1
Fifth: 0.74
Sixth: 0.5
Reverse: 2.9
Final Drive Ratio: 3.42
Maximum validated gross vehicle weight: 4000 lb ( 1680 kg )
Case material: aluminum
Center distance: 85mm
Fluid type: Texaco ATF Type III 1863
Transmission weight: wet: 54.9 kg (121 lb ) 61.5kg
Fluid capacity (approximate): dry: 3.8L (4.0 qt) 117 oz.
Power take off: no
Applications: Chevrolet Corvette
Chevrolet Corvette Z06
