P0400 Exhaust Gas Recirculation Flow Malfunction  P0401 Exhaust Gas Recirculation Flow Insufficient Detected  P0402 Exhaust Gas Recirculation Flow Excessive Detected  P0403 Exhaust Gas Recirculation Circuit Malfunction  P0404 Exhaust Gas Recirculation Circuit Range/Performance  P0405 Exhaust Gas Recirculation Sensor A Circuit Low  P0406 Exhaust Gas Recirculation Sensor A Circuit High  P0407 Exhaust Gas Recirculation Sensor B Circuit Low  P0408 Exhaust Gas Recirculation Sensor B Circuit High  P0410 Secondary Air Injection System Malfunction  P0411 Secondary Air Injection System Incorrect Flow Detected  P0412 Secondary Air Injection System Switching Valve A Circuit Malfunction  P0413 Secondary Air Injection System Switching Valve A Circuit Open  P0414 Secondary Air Injection System Switching Valve A Circuit Shorted  P0415 Secondary Air Injection System Switching Valve B Circuit Malfunction  P0416 Secondary Air Injection System Switching Valve B Circuit Open  P0417 Secondary Air Injection System Switching Valve B Circuit Shorted  P0418 Secondary Air Injection System Relay A" Circuit Malfunction  P0419 Secondary Air Injection System Relay "B Circuit Malfunction  P0420 Catalyst System Efficiency Below Threshold (Bank 1)  P0421 Warm Up Catalyst Efficiency Below Threshold (Bank 1)  P0422 Main Catalyst Efficiency Below Threshold (Bank 1)  P0423 Heated Catalyst Efficiency Below Threshold (Bank 1)  P0424 Heated Catalyst Temperature Below Threshold (Bank 1)  P0430 Catalyst System Efficiency Below Threshold (Bank 2)  P0431 Warm Up Catalyst Efficiency Below Threshold (Bank 2)  P0432 Main Catalyst Efficiency Below Threshold (Bank 2)  P0433 Heated Catalyst Efficiency Below Threshold (Bank 2)  P0434 Heated Catalyst Temperature Below Threshold (Bank 2)  P0440 Evaporative Emission Control System Malfunction  P0441 Evaporative Emission Control System Incorrect Purge Flow  P0442 Evaporative Emission Control System Leak Detected (small leak)  P0443 Evaporative Emission Control System Purge Control Valve Circuit  P0444 Evaporative Emission Control System Purge Control Valve Circuit Open  P0445 Evaporative Emission Control System Purge Control Valve Circuit Shorted  P0446 Evaporative Emission Control System Vent Control Circuit Malfunction  P0447 Evaporative Emission Control System Vent Control Circuit Open  P0448 Evaporative Emission Control System Vent Control Circuit Shorted  P0449 Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction  P0450 Evaporative Emission Control System Pressure Sensor Malfunction  P0451 Evaporative Emission Control System Pressure Sensor Range/Performance  P0452 Evaporative Emission Control System Pressure Sensor Low Input  P0453 Evaporative Emission Control System Pressure Sensor High Input  P0454 Evaporative Emission Control System Pressure Sensor Intermittent  P0455 Evaporative Emission Control System Leak Detected (gross leak) (FUEL CAP)  P0456 Evaporative Emissions System - Small leak detected (FUEL CAP)  P0457 ""  P0458 ""  P0459 ""  P0460 Fuel Level Sensor Circuit Malfunction  P0461 Fuel Level Sensor Circuit Range/Performance  P0462 Fuel Level Sensor Circuit Low Input  P0463 Fuel Level Sensor Circuit High Input  P0464 Fuel Level Sensor Circuit Intermittent  P0465 Purge Flow Sensor Circuit Malfunction  P0466 Purge Flow Sensor Circuit Range/Performance  P0467 Purge Flow Sensor Circuit Low Input  P0468 Purge Flow Sensor Circuit High Input  P0469 Purge Flow Sensor Circuit Intermittent  P0470 Exhaust Pressure Sensor Malfunction  P0471 Exhaust Pressure Sensor Range/Performance  P0472 Exhaust Pressure Sensor Low  P0473 Exhaust Pressure Sensor High  P0474 Exhaust Pressure Sensor Intermittent  P0475 Exhaust Pressure Control Valve Malfunction  P0476 Exhaust Pressure Control Valve Range/Performance  P0477 Exhaust Pressure Control Valve Low  P0478 Exhaust Pressure Control Valve High  P0479 Exhaust Pressure Control Valve Intermittent  P0480 Cooling Fan I Control Circuit Malfunction  P0481 Cooling Fan 2 Control Circuit Malfunction  P0482 Cooling Fan 3 Control Circuit Malfunction  P0483 Cooling Fan Rationality Check Malfunction  P0484 Cooling Fan Circuit Over Current  P0485 Cooling Fan Power/Ground Circuit Malfunction
DTC Codes - P0500-P0599  Vehicle Speed Controls and Idle Control System
 P0500 Vehicle Speed Sensor Malfunction  P0501 Vehicle Speed Sensor Range/Performance  P0502 Vehicle Speed Sensor Low Input  P0503 Vehicle Speed Sensor Intermittent/Erratic/High  P0505 Idle Control System Malfunction  P0506 Idle Control System RPM Lower Than Expected  P0507 Idle Control System RPM Higher Than Expected  P0510 Closed Throttle Position Switch Malfunction  P0520 Engine Oil Pressure Sensor/Switch Circuit Malfunction  P0521 Engine Oil Pressure Sensor/Switch Circuit Range/Performance  P0522 Engine Oil Pressure Sensor/Switch Circuit Low Voltage  P0523 Engine Oil Pressure Sensor/Switch Circuit High Voltage  P0530 A/C Refrigerant Pressure Sensor Circuit Malfunction  P0531 A/C Refrigerant Pressure Sensor Circuit Range/Performance  P0532 A/C Refrigerant Pressure Sensor Circuit Low Input  P0533 A/C Refrigerant Pressure Sensor Circuit High Input  P0534 Air Conditioner Refrigerant Charge Loss  P0550 Power Steering Pressure Sensor Circuit Malfunction  P0551 Power Steering Pressure Sensor Circuit Range/Performance  P0552 Power Steering Pressure Sensor Circuit Low Input  P0553 Power Steering Pressure Sensor Circuit High Input  P0554 Power Steering Pressure Sensor Circuit Intermittent  P0560 System Voltage Malfunction  P0561 System Voltage Unstable  P0562 System Voltage Low  P0563 System Voltage High  P0565 Cruise Control On Signal Malfunction  P0566 Cruise Control Off Signal Malfunction  P0567 Cruise Control Resume Signal Malfunction  P0568 Cruise Control Set Signal Malfunction  P0569 Cruise Control Coast Signal Malfunction  P0570 Cruise Control Accel Signal Malfunction  P0571 Cruise Control/Brake Switch A Circuit Malfunction  P0572 Cruise Control/Brake Switch A Circuit Low  P0573 Cruise Control/Brake Switch A Circuit High  P0574 Cruise Control Related Malfunction  P0575 Cruise Control Related Malfunction  P0576 Cruise Control Related Malfunction  P0576 Cruise Control Related Malfunction  P0578 Cruise Control Related Malfunction  P0579 Cruise Control Related Malfunction  P0580 Cruise Control Related Malfunction
DTC Codes - P0600-P0699  Computer Output Circuit
 P0600 Serial Communication Link Malfunction  P0601 Internal Control Module Memory Check Sum Error  P0602 Control Module Programming Error  P0603 Internal Control Module Keep Alive Memory (KAM) Error  P0604 Internal Control Module Random Access Memory (RAM) Error  P0605 Internal Control Module Read Only Memory (ROM) Error  P0606 PCM Processor Fault  P0608 Control Module VSS Output "A Malfunction  P0609 Control Module VSS Output "B" Malfunction  P0620 Generator Control Circuit Malfunction  P0621 Generator Lamp "L" Control Circuit Malfunction  P0622 Generator Field "F" Control Circuit Malfunction  P0650 Malfunction Indicator Lamp (MIL) Control Circuit Malfunction  P0654 Engine RPM Output Circuit Malfunction  P0655 Engine Hot Lamp Output Control Circuit Malfunction  P0656 Fuel Level Output Circuit Malfunction
DTC Codes - P0700-P0899  Transmission
 P0700 Transmission Control System Malfunction  P0701 Transmission Control System Range/Performance  P0702 Transmission Control System Electrical  P0703 Torque Converter/Brake Switch B Circuit Malfunction  P0704 Clutch Switch Input Circuit Malfunction  P0705 Transmission Range Sensor Circuit malfunction (PRNDL Input)  P0706 Transmission Range Sensor Circuit Range/Performance  P0707 Transmission Range Sensor Circuit Low Input  P0708 Transmission Range Sensor Circuit High Input  P0709 Transmission Range Sensor Circuit Intermittent  P0710 Transmission Fluid Temperature Sensor Circuit Malfunction  P0711 Transmission Fluid Temperature Sensor Circuit Range/Performance  P0712 Transmission Fluid Temperature Sensor Circuit Low Input  P0713 Transmission Fluid Temperature Sensor Circuit High Input  P0714 Transmission Fluid Temperature Sensor Circuit Intermittent  P0715 Input/Turbine Speed Sensor Circuit Malfunction  P0716 Input/Turbine Speed Sensor Circuit Range/Performance  P0717 Input/Turbine Speed Sensor Circuit No Signal  P0718 Input/Turbine Speed Sensor Circuit Intermittent  P0719 Torque Converter/Brake Switch B Circuit Low  P0720 Output Speed Sensor Circuit Malfunction  P0721 Output Speed Sensor Range/Performance  P0722 Output Speed Sensor No Signal  P0723 Output Speed Sensor Intermittent  P0724 Torque Converter/Brake Switch B Circuit High  P0725 Engine Speed input Circuit Malfunction  P0726 Engine Speed Input Circuit Range/Performance  P0727 Engine Speed Input Circuit No Signal  P0728 Engine Speed Input Circuit Intermittent  P0730 Incorrect Gear Ratio  P0731 Gear I Incorrect ratio  P0732 Gear 2 Incorrect ratio  P0733 Gear 3 Incorrect ratio  P0734 Gear 4 Incorrect ratio  P0735 Gear 5 Incorrect ratio  P0736 Reverse incorrect gear ratio  P0740 Torque Converter Clutch Circuit Malfunction  P0741 Torque Converter Clutch Circuit Performance or Stuck Off  P0742 Torque Converter Clutch Circuit Stock On  P0743 Torque Converter Clutch Circuit Electrical  P0744 Torque Converter Clutch Circuit Intermittent  P0745 Pressure Control Solenoid Malfunction  P0746 Pressure Control Solenoid Performance or Stuck Off  P0747 Pressure Control Solenoid Stuck On  P0748 Pressure Control Solenoid Electrical  P0749 Pressure Control Solenoid Intermittent  P0750 Shift Solenoid A Malfunction  P0751 Shift Solenoid A Performance or Stuck Off  P0752 Shift Solenoid A Stuck On  P0753 Shift Solenoid A Electrical  P0754 Shift Solenoid A Intermittent  P0755 Shift Solenoid B Malfunction  P0756 Shift Solenoid B Performance or Stock Off  P0757 Shift Solenoid B Stuck On  P0758 Shift Solenoid B Electrical  P0759 Shift Solenoid B Intermittent  P0760 Shift Solenoid C Malfunction  P0761 Shift Solenoid C Performance or Stuck Off  P0762 Shift Solenoid C Stuck On  P0763 Shift Solenoid C Electrical  P0764 Shift Solenoid C Intermittent  P0765 Shift Solenoid D Malfunction  P0766 Shift Solenoid D Performance or Stuck Off  P0767 Shift Solenoid D Stuck On  P0768 Shift Solenoid D Electrical  P0769 Shift Solenoid D Intermittent  P0770 Shift Solenoid E Malfunction  P0771 Shift Solenoid E Performance or Stuck Off  P0772 Shift Solenoid E Stuck On  P0773 Shift Solenoid E Electrical  P0774 Shift Solenoid E Intermittent  P0780 Shift Malfunction  P0781 1-2 Shift Malfunction  P0782 2-3 Shift Malfunction  P0783 3-4 Shift Malfunction  P0784 4-5 Shift Malfunction  P0785 Shift/Timing Solenoid Malfunction  P0786 Shift/Timing Solenoid Range/Performance  P0787 Shift/Timing Solenoid Low  P0788 Shift/Timing Solenoid High  P0789 Shift/Timing Solenoid Intermittent  P0790 Normal/Performance Switch Circuit Malfunction  P0801 Reverse Inhibit Control Circuit Malfunction  P0803 1-4 Upshift (Skip Shift) Solenoid Control Circuit Malfunction  P0804 1-4 Upshift (Skip Shift) Lamp Control Circuit Malfunction
GM-Specific P-Codes
 P1000 OBD-II Monitor Testing Incomplete.  P1001 KOER Test Cannot Be Completed.  P1039 Vehicle Speed Signal Missing or Improper.  P1051 Brake Switch Signal Missing or Improper.  P1100 Mass Air Flow Sensor Intermittent.  P1101 Mass Air Flow Sensor out of Self-Test Range.  P1112 Intake Air Temperature Sensor Intermittent.'  P1116 Engine Coolant Temperature Sensor is out of Self-Test Range.  P1117 Engine Coolant Temperature Sensor Intermittent.  P1120 Throttle Position Sensor out of range.  P1121 Throttle Position Sensor Inconsistent with Mass Air Flow Sensor.  P1124 Throttle Position Sensor out of Self-Test Range.  P1125 Throttle Position Sensor Intermittent.  P1127 Heated Oxygen Sensor Heater not on During KOER Test.  P1128 Heated Oxygen Sensor Signals reversed.  P1129 Heated Oxygen Sensor Signals reversed.  P1130 Lack of Upstream Heated Oxygen Sensor Switch - Adaptive Fuel Limit - Bank No. 1.  P1131 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 1.  P1132 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank No. 1.  P1135 Ignition Switch Signal Missing or Improper.  P1137 Lack of Downstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 1.  P1138 Lack of Downstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank No. 1.  P1150 Lack of Upstream Heated Oxygen Sensor Switch - Adaptive Fuel Limit - Bank No. 2.  P1151 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 2.  P1152 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank No. 2.  P1157 Lack of Downstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 2.  P1158 Lack of Downstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank No. 2.  P1220 Series Throttle Control fault.  P1224 Throttle Position Sensor B out of Self-Test Range.  P1230 Open Power to Fuel Pump circuit.  P1231 High Speed Fuel Pump Relay activated.  P1232 Low Speed Fuel Pump Primary circuit failure.  P1233 Fuel Pump Driver Module off-line.  P1234 Fuel Pump Driver Module off-line.  P1235 Fuel Pump Control out of range.  P1236 Fuel Pump Control out of range.  P1237 Fuel Pump Secondary circuit fault.  P1238 Fuel Pump Secondary circuit fault.  P1250 Lack of Power to FPRC Solenoid.  P1260 Theft Detected - Engine Disabled.  P1270 Engine RPM or Vehicle Speed Limiter Reached.  P1288 Cylinder Head Temperature Sensor out of Self-Test Range.  P1289 Cylinder Head Temperature Sensor Signal Greater Than Self Test Range.  P1290 Cylinder Head Temperature Sensor Signal Less Than Self-Test Range.  P1299 Cylinder Head Temperature Sensor Detected Engine Overheating Condition.  P1309 Misfire Detection Monitor not enabled.  P1351 Ignition Diagnostic Monitor circuit Input fault.  P1352 Ignition Coil A - Primary circuit fault.  P1353 Ignition Coil B - Primary circuit fault.  P1354 Ignition Coil C - Primary circuit fault.  P1355 Ignition Coil D - Primary circuit fault.  P1356 Loss of Ignition Diagnostic Module Input to PCM.  P1358 Ignition Diagnostic Monitor Signal out of Self-Test Range.  P1359 Spark Output circuit fault.  P1364 Ignition Coil Primary circuit fault.  P1380 VCT Solenoid Valve circuit Short or Open.  P1381 Cam Timing Advance is excessive.  P1383 Cam Timing Advance is excessive.  P1390 Octane Adjust out of Self-Test Range.  P1400 Differential Pressure Feedback Electronic Sensor circuit Low Voltage.  P1401 Differential Pressure Feedback Electronic Sensor circuit High Voltage.  P1403 Differential Pressure Feedback Electronic Sensor Hoses Reversed.  P1405 Differential Pressure Feedback Electronic Sensor circuit Upstream Hose.  P1406 Differential Pressure Feedback Electronic Sensor circuit Downstream Hose.  P1407 EGR No Flow Detected.  P1408 EGR Flow out of Self-Test Range.  P1409 EGR Vacuum Regulator circuit malfunction.  P1410 EGR Barometric Pressure Sensor VREF Voltage.  P1409 Electronic Vacuum Regulator Control circuit fault.  P1411 Secondary Air is not being diverted.  P1413 Secondary Air Injection System Monitor circuit Low Voltage.  P1414 Secondary Air Injection System Monitor circuit High Voltage.  P1442 Secondary Air Injection System Monitor circuit High Voltage.  P1443 Evaporative Emission Control System - Vacuum System -Purge Control Solenoid or Purge Control Valve fault.  P1444 Purge Flow Sensor circuit Input Low.  P1445 Purge Flow Sensor circuit Input High.  P1450 Inability of Evaporative Emission Control System to Bleed Fuel Tank.  P1451 Lack of Response From Passive Anti-Theft System Module - Engine Disabled.  P1452 Inability of Evaporative Emission Control System to Bleed Fuel Tank.  P1455 Substantial Leak or Blockage in Evaporative Emission Control System.  P1460 Wide Open Throttle Air Conditioning Cutoff circuit malfunction.  P1461 Air Conditioning Pressure Sensor circuit Low Input.  P1462 Air Conditioning Pressure Sensor circuit high Input.  P1463 Air Conditioning Pressure Sensor Insufficient Pressure change.  P1464 ACCS to PCM High During Self-Test.  P1469 Low Air Conditioning Cycling Period.  P1473 Fan Secondary High with Fans Off.  P1474 Low Fan Control Primary circuit.  P1479 High Fan Control Primary circuit.  P1480 Fan Secondary Low with Low Fans On.  P1481 Fan Secondary Low with High Fans On.  P1483 Power to Cooling Fan Exceeded Normal Draw.  P1484 Variable Load Control Module Pin 1 Open.  P1500 Vehicle Speed Sensor Intermittent.  P1501 Programmable Speedometer & Odometer Module/Vehicle Speed Sensor Intermittent circuit-failure.  P1502 Invalid or Missing Vehicle Speed Message or Brake Data.  P1504 Intake Air Control circuit malfunction.  P1505 Idle Air Control System at Adaptive Clip.  P1506 Idle Air Control Over Speed Error.  P1507 Idle Air Control Under Speed Error.  P1512 Intake Manifold Runner Control Stuck Closed.  P1513 Intake Manifold Runner Control Stuck Closed.  P1516 Intake Manifold Runner Control Input Error.  P1517 Intake Manifold Runner Control Input Error.  P1518 Intake Manifold Runner Control fault - Stuck Open.  P1519 Intake Manifold Runner Control Stuck Open.  P1520 Intake Manifold Runner Control circuit fault.  P1519 Intake Manifold Runner Control fault - Stuck Closed.  P1520 Intake Manifold Runner Control fault.  P1530 Open or Short to A/C Compressor Clutch circuit.  P1537 Intake Manifold Runner Control Stuck Open.  P1538 Intake Manifold Runner Control Stuck Open.  P1539 Power to A/C Compressor Clutch circuit Exceeded Normal Current Draw.  P1549 Intake Manifold Temperature Valve Vacuum Actuator Connection.  P1550 Power Steering Pressure Sensor out of Self-Test Range.  P1605 PCM Keep Alive Memory Test Error.  P1625 Voltage to Vehicle Load Control Module Fan circuit not detected.  P1626 Voltage to Vehicle Load Control Module circuit not detected.  P1650 Power Steering Pressure Switch out of Self-Test Range.  P1651 Power Steering Pressure Switch Input fault.  P1700 Transmission system problems.  P1701 Reverse Engagement Error.  P1702 Transmission system problems.  P1703 Brake On/Off Switch out of Self-Test Range.  P1704 Transmission system problems.  P1705 Manual Lever Position Sensor out of Self-Test Range.  P1709 Park or Neutral Position Switch out of Self-Test Range.  P1710 Transmission system problems.  P1711 Transmission Fluid Temperature Sensor out of Self-Test Range.  P1728 Transmission system problems.  P1729 4x4 Low Switch Error.  P1740 Transmission system problems.  P1741 Torque Converter Clutch Control Error.  P1742 Torque Converter Clutch Solenoid Faulty.  P1743 Torque Converter Clutch Solenoid Faulty.  P1744 Torque Converter Clutch System Stuck in Off Position.  P1745 Transmission system problems.  P1746 Electronic Pressure Control Solenoid - Open circuit.  P1747 Electronic Pressure Control Solenoid - Short circuit.  P1749 Electronic Pressure Control Solenoid Failed Low.  P1751 Shift Solenoid No. 1 Performance.  P1754 Coast Clutch Solenoid circuit malfunction.  P1756 Shift Solenoid No. 2 Performance.  P1760 Transmission system problems.  P1761 Shift Solenoid No. 3 Performance.  P1762 Transmission system problems.  P1767 Transmission system problems.  P1780 Transmission Control Switch circuit is out of Self-Test Range.  P1781 4x4 Low Switch is out of Self-Test Range.  P1783 Transmission Over-Temperature Condition.  P1784 Transmission system problems.  P1785 Transmission system problems.  P1786 Transmission system problems.  P1787 Transmission system problems.  P1788 Transmission system problems.  P1789 Transmission system problems.  P1870 Transmission system problems.  P1900 Transmission system problems.
