Stroker combinations for Small Block Chevrolet
CID Block Bore OverBore Crank Stroke RodLength Notes
334 305 3.766 .030 400 3.75 5.565 or 5.7 Crank main journals ground to 305 main size Must check rod balance pad to piston clearance (underside of pston cup)
366 350 4 .030 350 3.6 5.7 or 6.0 Must ofset gridn crank to achieve 3.60 stroke Must check rod balance pad to piston clearance (underside of piston cup) when using 6.0 rod
377 400 4.125 .030 350 3.48 5.7 or 6.0 User spacers and 350 main bearings or use special spacer bearings
383 350 4 .030 400 3.75 5.565, 5.7, 6.0 Turn crank main journals to 350 main size or use custom 383 crank
410 400 4.125 .015 400 3.81 6.0 Offset grind crank to 3.81 stroke Check rod to block and rod to cam clearance
420 400 4.125 .015 Custom 3.875 5.85 Check rod to block and rod to cam clearance
434 Custom 4.155 None Custom 4 6.0 or 6.125 Use Dart or GM Rocket block with .391 raised cam
454 Custom 4.19 None Custom 4.125 6.0 or 6.125 Use Dart or GM Rocket block with .391 raised cam
