2007 "LS2" 6.0L V8 (LS2) Car
Type: 6.0L Gen IV V8 Small Block
Displacement: 5970cc (364.3 ci)
Compression ratio: 10.9:1
Valve configuration: overhead valves (2 valves per cylinder)
Assembly site: St. Catharines, Ontario
Valve lifters: hydraulic roller
Firing order: 1 - 8 - 7 - 2 - 6 - 5 - 4 - 3
Bore x stroke: 101.6 x 92mm
Fuel system: sequential fuel injection
Fuel type: premium fuel recommended
Applications: Horsepower: hp ( kw )
Chevrolet Corvette 400 hp (298 kw) @ 6000 rpm
Cadillac CTSV
Applications: Torque: lb-ft. ( Nm )
Chevrolet Corvette 400 lb-ft (542 Nm) @ 4400 rpm
Cadillac CTSV 395 lb-ft (536 Nm) @ 4400 rpm
Fuel shut off: 6600 rpm
Emissions controls: catalytic converter
three-way catalyst
positive crankcase ventilation
Materials:
Block: cast aluminum
Cylinder head: cast aluminum
Intake manifold: composite
Exhaust manifold: cast nodular iron
Main bearing caps: powder metal
Crankshaft: cast iron with undercut and rolled fillets
Camshaft: hollow steel
Connecting rods: forged powder metal
Additional features: extended life spark plugs
extended life coolant
oil level sensor
Oil Life System
