Tools Required
J 35667-A Cylinder Head Leakdown Tester or equivalent
Caution
Before servicing any electrical component, the ignition key must be in the OFF or LOCK position and all electrical loads must be OFF, unless instructed otherwise in these procedures. If a tool or equipment could easily come in contact with a live exposed electrical terminal, also disconnect the negative battery cable. Failure to follow these precautions may cause personal injury and/or damage to the vehicle or its components.
Important
A leakage test may be performed in order to measure cylinder/combustion chamber leakage. High cylinder leakage may indicate one or more of the following:
Worn or burnt valves
Broken valve springs
Stuck valve lifters
Incorrect valve lash
Damaged piston
Worn piston rings
Worn or scored cylinder bore
Damaged cylinder head gasket
Cracked or damaged cylinder head
Cracked or damaged engine block
Disconnect the battery ground negative cable.
Remove the spark plugs.
Rotate the crankshaft to place the piston in the cylinder being tested at top dead center (TDC) of the compression stroke.
Install the J 35667-A or equivalent.
Important
It may be necessary to hold the crankshaft balancer bolt to prevent the crankshaft from rotating.
Apply shop air pressure to the J 35667-A and adjust according to the manufacturers instructions.
Record the cylinder leakage value. Cylinder leakage that exceeds 25 percent is considered excessive and may require component service. In excessive leakage situations, inspect for the following conditions:
Air leakage noise at the throttle body or air inlet hose that may indicate a worn or burnt intake valve or a broken valve spring.
Air leakage noise at the exhaust system tailpipe that may indicate a worn or burnt exhaust valve or a broken valve spring.
Air leakage noise from the crankcase, oil level indicator tube, or oil fill tube that may indicate worn piston rings, a damaged piston, a worn or scored cylinder bore, a damaged engine block or a damaged cylinder head.
Air bubbles in the cooling system may indicate a damaged cylinder head or a damaged cylinder head gasket.
Perform the leakage test on the remaining cylinders and record the values.
