One way engine have been found leaking oil is man-made as whoever installs the cooler to engine is causing cooler leaks by the tool
they are using
Notice to the left of the yellow line I put that the extension of tool installing bolt puts pressure on the cooler and breaking enough to then leak out
Techs at dealers are finding where the engine oil is leaking is at that damaged point.
