The lack of concern related to the E-Ray's EV range is made evident as soon as you look at the battery pack inside the car, which measures in at only 1.9 kWh. For comparison, the battery inside the Ferrari SF90 is 7.9 kWh. That battery allows the Ferrari to travel eight miles in pure electric mode, while GM does not provide any such metrics for future customers. That difference is a philosophical one, as Corvette chief engineer Josh Holder explained
“This is not an energy storage device for a range EV,” said Holder. “It's all about, you know, enhancing performance, expanding the performance envelope, delivering it when the car asks for it and being at the ready all the time.”
The hybrid system inside the Corvette E-Ray shares nothing with GM’s broader Ultium program vehicles.
The battery itself is constructed of 80 pouch cells, which contain bespoke battery chemistry for the E-Ray platform. Holder likens the setup to a slow-moving capacitor more than a traditional hybrid battery. The batteries are mounted inside the car’s center tunnel section, as was intended from the outset of the C8 platform.
This helps keep the 100-pound battery in the center of the car, with the weight sitting as low to the ground as possible to cut down on any negative handling impacts. E-Ray buyers won’t plug the car in to charge, as the battery is topped up through driving alone. This can be done in little more than a mile of driving in the Charge+ mode.
The batteries work in tandem with a single electric motor mounted on the front axle. That part is also unique to the Corvette. This marks the first time that all-wheel drive has been brought to the Corvette platform. The motor case is compact and made from magnesium, while aluminum fasteners help keep things svelte. There’s even a miniature dry sump oiling system tucked inside the case.
The motor itself only weighs in at about 80 pounds, which is still enough to shift the weight distribution forward a single percent. The hybrid components all together add some 260 pounds to the car, according to Holder, with GM reporting a dry weight of 3774 pounds. Weight penalty aside, the E-Ray’s electric motor brings 160 horsepower and 125 lb-ft of torque to the equation. When combined with the naturally aspirated 6.2-liter V-8 out back, the Corvette E-Ray is ready with 655 hp and 595 lb-ft of torque.
Thanks to the added grip and torque fill from the front axle, GM says the E-Ray can do 0-60 mph in just 2.5 seconds, before eclipsing the quarter-mile in just 10.5 seconds. That’s a tenth quicker than the all-mighty Z06 through both metrics, making this hybrid the quickest Corvette ever produced.
“I tell people the way it drives and the way it feels around town, it’s like, instead of a 6.2-liter small block, you’ve got an 8.0-liter small block,” executive chief engineer Tadge Juechter said
Take a ride in the Corvette E-Ray, as I did, and the sensation of a powerful naturally aspirated motor is certainly at the forefront. There's torque down low like you'd expect in any Corvette, but much more of it than ever before.
The eAWD system ensures all of that thrust makes its way to the ground and allows for some unique front-end behavior.
"I think the E-Ray will help reinforce and convince not just our customers, but people that will be our customers, that we’re going to do electrification not just to meet a mandate, but actually make the car better," Holder stated
