Joined: Dec 2000 Posts: 6,036teamzr1 Owner - Pays the bills
ECM Fault Code List C4 (ZR-1 LT5; VIN J) Code Definition 13 Left Oxygen Sensor (Open) 14 Coolant Sensor (High Temp) 15 Coolant Sensor (Low Temp) 16 DIS Fault Line Malfunction 21 TPS (Voltage High) 22 TPS (Voltage Low) 23 IAT Sensor (Temp Low) 24 Vehicle Speed Sensor 25 IAT Sensor (Temp High) 31 Cam Sensor Signal Problem 33 MAP Sensor (Voltage High) 34 MAP Sensor (Voltage Low) 36 DIS Fault Line/Missing or Extra EST Signal 41 Cylinder Select Error 42 EST System Malfunction 43 ESC System Malfunction 44 Left Oxygen Sensor (Lean) 45 Left Oxygen Sensor (Rich) 46 PASS-Key Circuit 51 MEM-CAL Problem 52 Engine Oil Temp Sensor (Low Temp) 53 System Voltage Error 54 Fuel Pump Voltage Low 55 Fuel Lean Monitor 56 Vacuum Sensor Voltage Problem 61 Secondary Port Throttle System Malfunction 62 Engine Oil Temp Sensor High 63 Right Oxygen Sensor Circuit (Open) 64 Right Oxygen Sensor (Lean) 65 Right Oxygen Sensor (Rich) 66 Engine Power Switch Voltage (High or Low)
ECM Fault Code List C4 (L98; VIN 8) Code Definition 13 Oxygen Sensor (Open) 14 Coolant Sensor (High Temp) 15 Coolant Sensor (Low Temp) 21 TPS (Voltage High) 22 TPS (Voltage Low) 23 IAT Sensor (Temp Low) 24 Vehicle Speed Sensor 25 IAT Sensor (Temp High) 32 EGR System Malfunction 33 MAP Sensor (Voltage High) 34 MAP Sensor (Voltage Low) 41 Cylinder Select Error 42 EST System Malfunction 43 ESC System Malfunction 44 Oxygen Sensor (System Lean) 45 Oxygen Sensor (System Rich) 46 PASS-Key Circuit 51 MEM-CAL Problem 52 Engine Oil Temp Sensor Low 53 System Voltage Problem 54 Fuel Pump Voltage Low 62 Engine Oil Temp Sensor High
CCM Fault Code List Code Definition 12 On-Board Diagnostics Operational; No Codes 13 DIC Switches Open or Shorted to B+ 14 DIC Switches Shorted to Ground 16 Ignition 3 Fuse Circuit Open 21 Horn Relay Coil Shorted to B+ or CCM Internal Open 22 Rear Defogger Relay Coil Shorted to B+ or CCM Internal Open 24 Courtesy Lamp Relay Coil Shorted to B+ or CCM Internal Open 25 Courtesy Lamp Relay Coil Circuit Open or Shorted to Ground 26 LCD Blanking Control Circuit Shorted to B+ or CCM Internal Open 27 LCD Blanking Control Circuit Open or Shorted to Ground 31 LCD Data Circuit Shorted to B+ or CCM Internal Open 32 LCD Data Circuit Open or Shorted to Ground 33 Data Clock Circuit Shorted to B+ or CCM Internal Open 34 Data Clock Circuit Open or Shorted to Ground 35 Data Strobe Circuit Shorted to B+ or CCM Internal Open 36 Data Strobe Circuit Open or Shorted to Ground 37 M Clock Circuit Shorted to B+ or CCM Internal Open 38 M Clock Circuit Open or Shorted to Ground 41 Loss of ECM Serial Data Communication 51 Pass-Key - Invalid Key Detection 52 Pass-Key - Key Detection Circuit Shorted 53 Pass-Key - Key Detection Circuit Open or Shorted to B+ 54 Pass-Key - Fuel Enable Failure 61 Pass-Key - Key # 1 Programming Resistance Out of Range 62 Pass-Key - Key # 2 Programming Resistance High 63 Pass-Key - Key # 2 Programming Resistance Low 71 LCD Dimming Output Circuit Shorted to B+ or CCM Internal Open 72 LCD Dimming Output Circuit Open or Shorted to Ground 73 LED Display Dimming Output Circuit Shorted to B+ or CCM Internal Open 74 LED Display Dimming Output Circuit Open or Shorted to Ground
LTPWS Fault Code List Code Definition 99 Receiver/Control Module Diagnosis 23 Right Tire Rear Low Tire 24 Right Tire Rear Sensor Fault 33 Left Tire Rear Low Tire 34 Left Tire Rear Sensor Fault 43 Left Tire Front Low Tire 44 Left Tire Front Sensor Fault 53 Right Tire Front Low Tire 54 Right Tire Front Sensor Fault
ABS Fault Code List Code Definition 21 Right Front Wheel Speed Sensor Fault 22 Right Front Toothed Wheel Frequency Error 25 Left Front Wheel Speed Sensor Fault 26 Left Front Toothed Wheel Frequency Error 31 Right Rear Wheel Speed Sensor Fault 32 Right Rear Toothed Wheel Frequency Error 35 Left Rear Wheel Speed Sensor Fault 36 Left Rear Toothed Wheel Frequency Error 41 Right Front Solenoid Valve Fault 45 Left Front Solenoid Valve Fault 55 Rear Wheels Solenoid Valve Fault 61 Pump Motor or Motor Relay Fault 63 Solenoid Valve Relay Fault 71 Electronic Brake Control Module Fault 72 Serial Data Line Fault 75 Lateral Accelerometer Fault (Short ot Open) 76 Lateral Accelerometer Fault (Signal out of Range)
SIR (Airbag) Fault Code List Code Definition 21 Steering Column Circuit Resistance too High 22 Steering Column Circuit Resistance too Low 23 Steering Column Circuit Voltage too High 23 Steering Column Circuit Voltage too Low 25 Short to Battery in Steering Column Circuit 26 Open in Steering Column Circuit 31 Open 36 VLT to Deployment Loop 32 Grounded 36 VLT to Deployment Loop 33 History Code, Diode B Shorted in Wiring Harness to Arming Sensor 34 Open in Ignition 1 Feed to Deployment Loop 35 Discriminating Sensor Open 41 and / or 42 Deployment Loop Energy Reserve Voltage Fault 51 Accident Detected 52 EEPROM Accident Data Area Full 61 Force Low or "INFL REST" Warning Lamp Circuit Failure 71 Internal DERM Fault
Automatic Air Conditioning Fault Code List 01 + 02 Temperature Door Motor Circuit Fault 03 (Open) + 04 (Short) Outside (Ambient) Air Temperature Sensor Fault 05 (Open) + 06 (Short) In-Vehicle Temperature Sensor Circuit Fault 07 (Open) + 08 (Short) Solar (Sun-Load) Sensor Circuit Fault Open or Shorted 09 Low Freon Detected 10 or --- Uart or "E" and "C" Bus Failure Diagnostic mode = push and hold the fan "up" arrow and fan "down" arrow at the same time (5 sec.) Push "Auto Fan" to show the fault codes LED flash at 60 times per minute = Fault codes be stored Reset = Remove Negative Battery Cable for 1 Minute
Code Liste Selective Ride Control FX3:
12 Start of code sequence 13 Left Rear time out 14 Right Front time out 21 Left Front time out 22 Right Rear time out 23 Loss of vehicle speed signal 31 Left Front out of position 32 Right Front out of position 33 Left Rear out of position 34 Right Rear out of position 41 Selective Ride Control Switch short to Voltage 42 Selective Ride Control Switch open cantacts 43 Selective Ride Control Switch open circuit
