Topics3,710
Posts6,899
Most Online425 Oct 19th, 2025
#6072 - 05/15/23 08:43 AM
Re: C4 Corvette ECM, CCM & EBTCM DTCs
[Re: teamzr1]
Module 4 is ECM
4.0 ECM waiting for interrogation instructions 4.1 display ECM fault codes ECM Fault Code List 1984-1991 (L98: VIN 8) Code Definition 12 No Distributor Reference Pulse (this code is displayed only when engine is not running) 13 Oxygen Sensor Open 14 Coolant Sensor High Temp 15 Coolant sensor Low Temp 21 TPS Voltage High 22 TPS Voltage Low 23 MAT Sensor Temp Low 24 Vehicle Speed Sensor 25 MAT Sensor Temp High 32 EGR System Error 33 MAP Sensor Voltage High 34 MAP Sensor Voltage Low 41 Cylinder Select Error 42 EST System Error 43 ESC System Error 44 Oxygen Sensor (System Lean) 45 Oxygen Sensor (System Rich) 46 VATS Error 51 Mem-Cal Error 52 Engine Oil Temp Sensor Low 53 System Voltage Error 54 Fuel Pump Voltage Low 62 Engine Oil Temp Sensor High
ECM Fault Code List 1990-1993(LT5/ZR-1; VIN J)
Code Definition 13 Left Oxygen Sensor Open 14 Coolant sensor High Temp 15 Coolant Sensor Low Temp 16 DIS Fault Line Error 21 TPS Voltage High 22 TPS Voltage Low 23 MAT Sensor Temp Low 24 Vehicle Speed Sensor 25 MAT Sensor Temp High 31 Cam Sensor Missing or Too Many Pulses 33 MAP Sensor Voltage High 34 MAP Sensor Voltage Low 36 DIS Fault Line/Missing or Extra EST Signal 41 Cylinder Select Error 42 EST System Error 43 ESC System Error 44 Oxygen Sensor (Left Bank Lean) 45 Oxygen Sensor (Right Bank Rich) 46 VATS Error 51 Mem-Cal Error 52 Engine Oil Temp Sensor Low 53 System Voltage Error 54 Fuel Pump Voltage Low 55 Fuel Monitor Lean 56 Port Throttle Vacuum Sensor Low or High 61 Secondary Port Throttle System Error 62 Engine Oil Temp Sensor High 63 Right Oxygen Sensor Circuit Open 64 Right Oxygen Sensor (Right Bank Lean) 65 Right Oxygen Sensor (Right Bank Rich)
1992-1996 (LT-1 VIN P)
DTC Codes 72-99 Pertain to 1994-1996 (LT-1 VIN P) Code Definition DTC 11 Malfunction Indicator Lamp (MIL) Circuit DTC 13 Bank 1Left Front) Heated Oxygen} Oxygen Sensor (H02S) #1 Circuit (Open Circuit) DTC 14 Engine Coolant Temperature (ECT) Sensor Circuit (Signal Voltage Low, High Temperature Indicated) DTC 15 Engine Coolant Temperature (ECT) Sensor Circuit (Signal Voltage High, Low Temperature Indicated) DTC 16 Distributor Ignition System (Low Resolution Pulse) DTC 18 Injector Circuit(s) DTC 21 Throttle Position (TP) Sensor Circuit (Signal Voltage High) DTC 22 Throttle Position (TP) Sensor Circuit (Signal Voltage Low) DTC 23 Intake Air Temperature (IAT) Sensor Circuit (Signal Voltage High, Low Temperature Indicated) DTC 24 Vehicle Speed Sensor (VSS) Circuit DTC 25 Intake Air Temperature (IAT) Sensor Circuit (Signal Voltage Low, High Temperature Indicated) DTC 26 Evaporative Emission (EVAP) Canister Purge Solenoid Valve Circuit DTC 27 Exhaust Gas Recirculation (EGR) Vacuum Control Signal Solenoid Valve Circuit DTC 28 Transmission Range (TA) Pressure Switch Assembly Fault DTC 29 Secondary Air Injection (AIR) Pump Circuit DTC 32 Exhaust Gas Recirculation (EGR) DTC 33 Manifold Absolute Pressure (MAP) Sensor Circuit (Signal Voltage High Low Vacuum) DTC 34 Manifold Absolute Pressure (MAP) Sensor Circuit (Signal Voltage Low High Vacuum) DTC 36 Distributor Ignition System (Faulty High Resolution Pulse or Extra Low Resolution Pulse Detected) DTC 37 Brake Switch Stuck ON DTC 38 Brake Switch Stuck OFF DTC 41 Ignition Control (IC) Circuit (Open Circuit) DTC 42 Ignition Control (IC) Circuit (Shorted or Grounded Circuit) DTC 43 Knock Sensor (KS) Circuit DTC 44 Bank 1 (Left Front) Heated Oxygen Sensor (HO2S) #1 Circuit (Lean Exhaust Indicated) DTC 45 Bank 1 (Left Front) Heated Oxygen Sensor (HO2S) #1 Circuit (Rich Exhaust Indicated) DTC 47 Knock Sensor (KS) Circuit or Module Missing DTC 48 Mass Air Flow (MAF) Sensor Circuit DTC 50 System Voltage Low DTC 51 EEPROM Programming Error DTC 52 Engine Oil Temperature Sensor Circuit (Signal Voltage High, Low Temperature Indicated) DTC 53 System Voltage High DTC 55 Fuel Lean Monitor DTC 58 Transmission Fluid Temperature (TFT) Sensor Circuit Low (High Temperature Indicated) DTC 59 Transmission Fluid Temperature (TFT) Sensor Circuit High (Low Temperature Indicated) DTC 62 Engine Oil Temperature Sensor Circuit (Signal Voltage Low, High Temperature Indicated) DTC 63 Bank 2 (Right Front) Heated Oxygen Sensor (HO2S) #1 Circuit (Open Circuit) DTC 64 Bank 2 (Right Front) Heated Oxygen Sensor (HO2S) #1 Circuit (Lean Exhaust Indicated) DTC 65 Bank 2 (Right Front) Heated Oxygen Sensor (HO2S) #t Circuit (Rich Exhaust Indicated) DTC 66 A/C Refrigerant Pressure Sensor Circuit (Open or Shorted) DTC 67 A/C Refrigerant Pressure Sensor Circuit (Pressure Sensor or A/C Clutch Circuit Problem) DTC 68 A/C Relay Circuit (Shorted Circuit) DTC 69 A/C Clutch Circuit DTC 70 A/C Clutch Relay Driver Circuit DTC 72 Vehicle Speed Sensor Loss DTC 73 Pressure Control Solenoid (PCS) Circuit (Current Error) DTC 74 Traction Control System (TCS) Circuit Low DTC 75 Transmission System Voltage Low DTC 77 Fan Control PCM Terminal All DTC 78 Fan Control PCM Terminal Al0 DTC 79 Transmission Fluid Over-temp DTC 81 Transmission .2-3 Shift Solenoid Circuit DTC 82 Transmission 1-2 Shift Solenoid Circuit DTC 83 TCC PWM Solenoid Circuit Fault DTC 84 3-2 Control Solenoid Circuit (Automatic Transmission) DTC 84 2nd and 3rd Gear Block-out Relay Control Circuit (Manual Transmission) DTC 85 Transmission TCC Stuck ON DTC 90 Transmission TCC Solenoid Circuit DTC 91 One to Four Up shift Lamp (Manual Transmission) DTC 97 VSS Output Circuit DTC 99 Tach Output Circuit DTC P0116 Engine Coolant Temperature (ECT) Circuit Range/Performance Problem DTC P0117 Engine Coolant Temperature (ECT) Circuit Low Input DTC P0118 Engine Coolant Temperature (ECT) Circuit High Input DTC P0131 Bank 1 HO2S #1 Circuit Low Voltage (Lean DTC P0132 Bank 1 HO2S #1 Circuit High Voltage (Rich) DTC P0133 Bank 1 HO2S #1 Circuit Slow Response DTC P0134 Bank 1 HO2S #1 Circuit No Activity Detected DTC P0135 Bank 1 HO2S #1 Heater Circuit DTC P0151 Bank 2 HO2S #1 Circuit Low Voltage (Lean) DTC P0152 Bank 2 HO2S #1 Circuit High Voltage (Rich) DTC P0153 Bank 2 HO2S #1 Circuit Slow Response DTC P0154 Bank 2 HO2S #1 Circuit No Activity Detected DTC P0155 Bank 2 HO2S #1 Heater Circuit Malfunction DTC P0158 Bank 2 HO2S #2 Circuit High Voltage DTC P0160 Bank 2 HO2S #2 Circuit No Activity Detected DTC P0161 Bank 2 HO2S #2 Heater Circuit Malfunction DTC P0171 Bank 1 Fuel Trim System Too Lean DTC P0172 Bank 1 Fuel Trim System Too Rich (1 of 2) DTC P0174 Bank 2 Fuel Trim System Too Lean DTC P0175 Bank 2 Fuel Trim System Too Rich (1 of 2) DTC PO420 Bank 2 Catalyst System Low Oxygen Storage Capacity Indicated DTC P1114 Engine Coolant Temperature (ECT) Circuit (intermittent Low Input Voltage) DTC P1115 Engine Coolant Temperature (ECT) Circuit (Intermittent High Input Voltage) DTC P1133 Bank 1 HO2S #1 Circuit Not Enough Switches DTC P1153 Bank 2 HO2S #1 Circuit Not Enough Switches DTC P1158 Bank 2 HO2S #2 Shifted Rich
1994-1995 LT5/ZR-1 Trouble codes
Due to federal regulations implementing uniform trouble codes throughout the automotive industry, LT5/ZR-1 Corvettes used many of the same 1994 and up codes, except for the codes listed below. (These trouble codes may be in addition to the possible codes above or different meaning) DTC 31 Camshaft Position Sensor Circuit DTC 41 Cylinder Select Error (Faulty or Incorrect PROM) DTC 54 Fuel Pump Circuit (Low Voltage) DTC 56 Secondary Air Inlet Valve Actuator Vacuum Sensor Circuit (Signal Voltage High High Vacuum or Signal Voltage Low (Low Vacuum) DTC 61 Secondary Air Inlet Valve System DTC 66 Engine Power Mode Switch Circuit (Signal Voltage High or Signal Voltage Low)
4.7 clear ECM fault codes Press the TRIP RESET button until 4.0 is displayed in the module number area. Then press the TRIP/ODO button until 4.7 is displayed in the module number area. Press and hold the ENG/MET button until is displayed. This will clear any ECM codes. After is displayed turn the key off, wait ten seconds turn the key back on and check for any ECM codes.
ABS/ASR EBTCM
Press the TRIP RESET button until 9.0 is displayed in the module number area. Press the TRIP/ODO button until 9.7 is displayed in the module number area. Press and hold the ENG/MET button until is displayed. This will clear any ABS/ASR codes. after is displayed, turn the key off, wait ten seconds, turn the key back on and check for any ABS/ASR codes.
11
guests, and
13
spiders. |
Admin,
Global Mod,
